> Would it be backward compatible for older CA clients/servers trying to
> connect the single-host multiple IOCs?
With multicast clients would send search messages to a special
ip address. That could be manually configured with
EPICS_CA_ADDR_LIST, but we could easily also allow the distribution
to be configured so that sending to the broadcast addresses,
multicast address, name server, no particular address is the
default. We could probably also allow a default configuration, set
in the distribution, which sends to more than one of the above.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Matthieu Bec [mailto:[email protected]]
> Sent: Friday, September 24, 2010 11:01 AM
> To: Jeff Hill
> Cc: [email protected]
> Subject: Re: Soft IOCs and Port Numbers
> On 09/24/10 08:33, Jeff Hill wrote:
> >> We are wondering here, how to host multiple soft
> >> IOCs on the same computer, possibly
> >> sharing the same UDP CA request port.
> > It is a simple matter to add multicast support to the
> > ca server, and that will address this issue.
> Of the different options I heard, it seems most transparent.
> Matthieu
> Matthieu Bec Gemini Observatory
> Tel: +56 51 205785 c/o AURA, Casilla 603
> Fax: +56 51 205650 La Serena, Chile
- Soft IOCs and Port Numbers Pam Gurd
- RE: Soft IOCs and Port Numbers matthew.pearson
- RE: Soft IOCs and Port Numbers Anze Zagar
- RE: Soft IOCs and Port Numbers Jeff Hill
- Re: Soft IOCs and Port Numbers Matthieu Bec
Re: Soft IOCs and Port Numbers Andrew Johnson
<2010>
<2010>
