Stephen,
Got it!!! At least everything is up and running. Need to check it out more
fully and understand next.
Thank you (and Andrew) for the help.
Scott
> From: Stephen Lewis <[email protected]>
> Date: Fri, 24 Sep 2010 15:27:41 -0500
> To: "[email protected]" <[email protected]>
> Cc: Andrew Johnson <[email protected]>, "[email protected]"
> <[email protected]>
> Subject: Re: vlinac and point release
> /sw/lib is where the fink package puts libraries.
> I had to install fink and then 'fink install readline5'. This is sufficient
> to run the IOC.
> I also installed openmotif4. medm ran fine but probe and alh did't. Eric
> Norum said to use openmotif3, not openmotif4. So I uninstalled openmotif4 and
> installed openmotif3, however, now they all are looking for
> '/sw/lib/libXm.4.dylib'.
> On 24 Sep 2010, at 13:15 , Akridge, Charles S. (MSFC-ES52) wrote:
>> Andrew,
>> I downloaded the new version, unzipped and double-clicked on
>> startIoc.command. This is the error message I received from the terminal:
>> --- begin -----
>> x-asset-user-Q40-2:~ cakridge$
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/startIoc.command ; exit;
>> dyld: Library not loaded: /sw/lib/libreadline.5.dylib
>> Referenced from:
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libca.3.14.1
>> 1.dylib
>> Reason: image not found
>> Referenced from:
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libseq.3.14.
>> 11.dylib
>> Trace/BPT trap
>> logout
>> --- end ---
>> Thank for the help.
>> Scott
>>> From: Andrew Johnson <[email protected]>
>>> Date: Tue, 21 Sep 2010 12:43:37 -0500
>>> Cc: "[email protected]" <[email protected]>
>>> Hi Scott,
>>> I updated, rebuilt and uploaded the vlinac_multi.tgz file, apologies that
>>> it's
>>> 20MB but it does include binaries and library files for all the Unix-like
>>> architectures we support. Most of the start* scripts needed modifications
>>> to
>>> add support for some newer architectures, I hope they should all work,
>>> although I haven't tested them all.
>>> http://www.aps.anl.gov/epics/download/examples/vlinac_multi.tgz
>>> Note that MEDM, ALH and StripTool are all fairly old tools now and a more
>>> modern example would probably use CS-Studio for the operator GUIs.
>>> - Andrew
>>> On Monday 20 September 2010 17:38:28 Akridge, Charles S. (MSFC-ES52) wrote:
>>>> Downloaded and attempted to run ³startProbe.command² but found out that the
>>>> build is for PowerPC not Intel. I have a MacBook Pro running MacOSX 10.6.4
>>>> and would prefer to get a point release for this Mac but if not I need I
>>>> need to understand how to compile vlinac for this machine.
>>>> BTW, I¹m rusty on reading a makefile so any step-by-step instructions or
>>>> better yet a point release would be great.
>>>> Scott
>>> The best FOSS code is written to be read by other humans -- Harald Welte
- Re: vlinac and point release Stephen Lewis
Re: vlinac and point release Andrew Johnson
ImageMagick Mark Rivers
<2010>
Re: vlinac and point release J. Lewis Muir
<2010>
