1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: always more inputs in gensub/asub
To: EPICS tech-talk <[email protected]>
Date: Mon, 27 Sep 2010 18:06:02 +0200
Consider using StreamDevice. Only the length of EPICS strings is limited but the length of StreamDevice messages is not (however Eric found a performance problem if the message is in the order of several megabytes). StreamDevice can take the values from 8 different (ao) records and combine them to one long message to the motor controller.
Dirk
[email protected] wrote:
I need to compute a command for a synchronous move of 8 motors.
The final command is possibly a long string (if I split it in 2, it would not be an atomic command!)
I have 7 parameters per motor and one final command line.
How would one program that?
Cascaded gensub is what I would normally do.
But is there a more elegant way?
always more inputs in gensub/asub emmanuel_mayssat
Prev: LabVIEW interfaces with EPICS Zhukov, Alexander P.
Next: Re: always more inputs in gensub/asub emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: always more inputs in gensub/asub emmanuel_mayssat
Next: Rocket Engine control Akridge, Charles S. (MSFC-ES52)
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
