1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiving system
Date: Tue, 28 Sep 2010 16:50:24 -0400
James,
I would check out the CSS archiver in use at the SNS. I have no direct experience with it but I do know
the system admin guys that would be unhappy if there were problems and whenever I mention the
CSS archiver they continue to smile.
John Sinclair
[email protected] wrote:
Hi
I'm afraid I won't be able to attend the EPICS meeting but see the older
messages on tech-talk from the various RDB archiver authors. Ralph makes
a good point that the only widely deployed archiver is the
non-relational Channel Archiver.
James
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: 28 September 2010 15:41
To: Dirk Martin
Cc: EPICS Tech Talk
Dirk,
James Rowland from Diamond recently did a poll and has the most current list of archiving solutions that are used with EPICS. I think he will talk about it at the upcoming EPICS Collaboration Meeting in two weeks.
My first order answer would be:
There's the Channel Archiver: old, stable, fast, very widely used, but not based on a RDB.
There are several other archiving solutions, some of which use a RDB for storage, others don't. Different ages, different languages, different file formats or RDB systems for storage. Their common feature: they are all used at one lab only, two labs maximum.
CSS databrowser support is available for the Channel Archiver, and for the Oracle-based archiver at SNS. (The latter might not be part of the DESY CSS.) There is experimental support for HyperArchiver (Channel Archiver writing into Hypertable).
While RDB-based archiving solutions have a tendency to be slower (as well in writing an archive as retrieving from it), I don't see an issue here for your system (unless your 10K channels are updating every second or faster).
Hope this helps,
Ralph
On 28.09.2010 10:23, Dirk Martin wrote:
Hallo,
at the S-DANILAC of the TU Darmstadt we're using EPICS to control power supplies for example. Since it is necessary to observe ~10000 PVs for a period of nearly four weeks, we decided to introduce an archiving system based upon a relational database. We're using CSS (from the DESY) and would like to plot the archived data in
the Data Browser.
That is why I ask you, whether you could tell me, which archiving system is wide-spreaded enough and best for this job.
Thanks in advance and best regards
Dirk Martin
Re: archiving system Patrick Thomas
Re: archiving system Martin Konrad
archiving system Dirk Martin
Re: archiving system Ralph Lange
RE: archiving system james.rowland
Prev: Re: CALC expression Ralph Lange
Next: Re: CALC expression Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: archiving system james.rowland
Next: Re: archiving system Patrick Thomas
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
