1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CALC expression
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Wed, 29 Sep 2010 12:15:50 -0500
On Wednesday 29 September 2010 11:15:25 Eric Norum wrote:
> How long has it been since someone actually tested vxWorks to see if it
> still exhibit this fragmentation issue? Sometimes urban legends are just
> that.
It seems that vxWorks 6.8 does use a best-fit algorithm for memory allocation,
with both the Kernel and RTP APIs.  However the vxWorks 5.5.x routines still
use first-fit, which is what causes the fragmentation to occur.  We might be
able to insist on vxWorks 6.x with future R3.15.x releases of Base, but even
there I think there might be some wailing and gnashing of teeth...
> > Alternatively we could add integer literal support to the code in
> > libCom/calc, which would reduce the incremental expansion factor from
> > 21/4 to 10/3 or better, but again that would be making code changes
> > uncomfortably late in the development cycle for 3.14.12.
> Are the changes that extensive?
I haven't written then yet, and I don't know if I'll have time in the next
week or so.  They are all localized within libCom/calc though, and there's a
pretty good unit test program now (which would also need updating BTW).
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
CALC expression Andrew Wagner
Re: CALC expression Andrew Johnson
Re: CALC expression Eric Norum
Prev: Re: CALC expression Pam Gurd
Next: Re: archiving system emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CALC expression Eric Norum
Next: RE: CALC expression Redman, Russell
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
