1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiling EPICS for cris v10
To: Burkhard Kolb <[email protected]>
Cc: Florian Feldbauer <[email protected]>, tech-talk Mailing List <[email protected]>
Date: Fri, 01 Oct 2010 14:01:36 +0200
PLT seens to mean "procedure linkage table". The compiler source code is here: https://www.calcforge.org/trac/emu-tigcc/browser/tiemu/trunk/src/core/gdb/bfd/elf32-cris.c?rev=1818
Of course, that does not mean that I have any clue what caused the error.
Dirk
Burkhard Kolb wrote:
Well Mark,
Peter Zumbruch posted the same error some time ago on 28th of June (subject: No PLT for relocation)
At that time nobody responded ...
We also still have no solution, it seems to be a linker problem with the cris-gnu stuff.
Burkhard
Am 30.09.2010 um 18:04 schrieb Mark Rivers:
I have never seen an error like that.
What type of system are you building for, an embedded IOC or a
workstation?
You are using asyn R4-10 which is quite old, and was tested with EPICS
3.14.8, but I don't think that is the problem.  Could you be running out
of memory on the target system?
It did build the executables in the asyn test directories OK, right?  So
the linker can build executables, just not your IOC executable?
-----Original Message-----
From: Florian Feldbauer [mailto:[email protected]] Sent: Thursday, September 30, 2010 10:29 AM
To: Mark Rivers
Cc: Florian Feldbauer; [email protected]
Subject: RE: Cross compiling EPICS for cris v10
Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
still I can't build my IOC application
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld: /usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
basyn.a(devAsynInt32.o): No PLT for relocation R_CRIS_32_GOTPLT against symbol `epicsRingBytesCreate' from .text section
xis-linux-gnu/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
Dr. Burkhard Kolb Pleikartsförster Str. 38
69124 Heidelberg
Germany
E-Mail: [email protected] Tel: +49 6221 718640 / Fax: +49 6221 718641
RE: Cross compiling EPICS for cris v10 Mark Rivers
Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Re: Cross compiling EPICS for cris v10 Burkhard Kolb
Prev: RE: Channel Archiver overlapping blocks james.rowland
Next: RE: Cross compiling EPICS for cris v10 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Cross compiling EPICS for cris v10 Burkhard Kolb
ANJ, 01 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
