1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cross compiling EPICS for cris v10
To: "Florian Feldbauer" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Fri, 1 Oct 2010 13:16:05 -0500
OK, I the problem is that it is linking with EPICS_BASE_IOC_LIBS first,
rather than last.
slowCtrl_registerRecordDeviceDriver.o slowCtrlMain.o
-lslowCtrlSupport
-lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc
-lregistryIoc -ldbStaticIoc -lca -lCom -lstream -lasyn -lcalc
-lstreamSynApps  -lpthread    -lm -lrt
You have a mixture of PROD_LIBS and slowCtrl_LIBS, and it must be doing
PROD_LIBS after slowCtrl_LIBS.
Change
slowCtrl_LIBS += $(EPICS_BASE_IOC_LIBS)
To
PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
-----Original Message-----
Sent: Friday, October 01, 2010 1:06 PM
To: Andrew Johnson
Cc: [email protected]; Florian Feldbauer; Mark Rivers
Subject: Re: Cross compiling EPICS for cris v10
Here's the makefile:
> TOP=../..
> include $(TOP)/configure/CONFIG
> #  ADD MACRO DEFINITIONS AFTER THIS LINE
> # Build the IOC support library
> LIBRARY_IOC += slowCtrlSupport
> PROD_LIBS += stream
> PROD_LIBS += asyn
> PROD_LIBS += calc
> PROD_LIBS += streamSynApps
> # xxxRecord.h will be created from xxxRecord.dbd
> DBDINC += xxxRecord
> # Install devXxxSoft.dbd into <top>/dbd
> DBD += xxxSupport.dbd
> # Compile and add the code to the support library
> slowCtrlSupport_SRCS += xxxRecord.c
> slowCtrlSupport_SRCS += devXxxSoft.c
> # Link locally-provided code into the support library,
> # rather than directly into the IOC application.
> slowCtrlSupport_SRCS += dbSubExample.c
> slowCtrlSupport_SRCS += slowCtrlHello.c
> slowCtrlSupport_SRCS += initTrace.c
> slowCtrlSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
> # Build the IOC application
> PROD_IOC = slowCtrl
> # slowCtrl.dbd will be created and installed
> DBD += slowCtrl.dbd
> # slowCtrl.dbd will be made up from these files:
> slowCtrl_DBD += base.dbd
> slowCtrl_DBD += xxxSupport.dbd
> slowCtrl_DBD += dbSubExample.dbd
> slowCtrl_DBD += slowCtrlHello.dbd
> slowCtrl_DBD += initTrace.dbd
> slowCtrl_DBD += slowCtrlInclude.dbd
> slowCtrl_DBD += stream.dbd
> slowCtrl_DBD += asyn.dbd
> # slowCtrl_registerRecordDeviceDriver.cpp derives from slowCtrl.dbd
> slowCtrl_SRCS += slowCtrl_registerRecordDeviceDriver.cpp
> # Build the main IOC entry point on workstation OSs.
> slowCtrl_SRCS_DEFAULT += slowCtrlMain.cpp
> slowCtrl_SRCS_vxWorks += -nil-
> # Add support from base/src/vxWorks if needed
> #slowCtrl_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
> # Link in the code from the support library
> slowCtrl_LIBS += slowCtrlSupport
> # NOTE: To build SNL programs, SNCSEQ must be defined
> # in the <top>/configure/RELEASE file
> ifneq ($(SNCSEQ),)
>     # Build sncExample into slowCtrlSupport
>     sncExample_SNCFLAGS += +r
>     slowCtrl_DBD += sncExample.dbd
>     slowCtrlSupport_SRCS += sncExample.stt
>     slowCtrlSupport_LIBS += seq pv
>     slowCtrl_LIBS += seq pv
>     # Build sncProgram as a standalone program
>     PROD_HOST += sncProgram
>     sncProgram_SNCFLAGS += +m
>     sncProgram_SRCS += sncProgram.st
>     sncProgram_LIBS += seq pv
>     sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
> endif
> # Finally link to the EPICS Base libraries
> include $(TOP)/configure/RULES
> #  ADD RULES AFTER THIS LINE
and here's the commandline:
/usr/local/cris/bin/cris-axis-linux-gnu-g++ -o slowCtrl -Wl,-Bstatic
-static-libgcc -Wl,--strip-all
-L/usr/Epics/base-3.14.10/lib/linux-cris_v10
-L/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cris_v10
-L/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10
-L/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10
-L/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/base-3.14.10/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/calc-2-8/lib/linux-cri
s_v10
-Wl,-rpath,/usr/Epics/slowCtrl_etrax/lib/linux-cris_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cr
is_v10
-Wl,-rpath,/usr/Epics/synApps/synApps_5_5/support/stream-2-4-1/lib/linux
-cris_v10
-L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/lib
-L/usr/local/devboard-R2_20//target/cris-axis-linux-gnu/usr/lib
-lslowCtrlSupport
/usr/Epics/synApps/synApps_5_5/support/asyn-4-13/lib/linux-cris_v10/liba
syn.a(devAsynInt32.o):
In function `getIoIntInfo':
epicsTypeClass/../../asyn/devEpics/devAsynInt32.c:288: undefined
reference
to `epicsRingBytesCreate'
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld:
No PLT for relocation R_CRIS_32_GOTPLT against symbol
`epicsRingBytesCreate' from .text section
final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory
`/usr/Epics/slowCtrl_etrax/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl_etrax/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
On Fri, 1 Oct 2010, Andrew Johnson wrote:
> On Friday 01 October 2010 07:53:33 Florian Feldbauer wrote:
>> I've just tested to build the example application using
makeBaseApp.pl
>> without changing any files. This works.
>> But as soon as I add Asyn and Stream I get the error.
> Repeating my request of yesterday, please post your IOC's Makefile and
> the command line of the link command that fails as printed by gnumake.
> It's sounding more and more like this may be a mistake in your
Makefile,
> that you're not linking all the libraries, or you have them in the
wrong
> order.
> - Andrew -- If a man is offered a fact which goes against his
instincts,
> he will scrutinize it closely, and unless the evidence is
overwhelming,
> he will refuse to believe it.  If, on the other hand, he is offered
> something which affords a reason for acting in accordance to his
> instincts, he will accept it even on the slightest evidence.  --
> Bertrand Russell
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Mark Rivers
Re: Cross compiling EPICS for cris v10 Andrew Johnson
Re: Cross compiling EPICS for cris v10 Florian Feldbauer
Prev: Re: Cross compiling EPICS for cris v10 Florian Feldbauer
Next: MOXA ARM computer and streamDevice Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Cross compiling EPICS for cris v10 Florian Feldbauer
ANJ, 01 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
