1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VDCT PostScript problem
To: "[email protected] tech-talk" <[email protected]>
Date: Fri, 1 Oct 2010 15:50:33 -0700
VDCT -- 2.6.1274 on OS X and on LInux
When I try to export as PostScript I get the following error:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
	at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
	at java.lang.StringBuffer.insert(StringBuffer.java:446)
	at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
	at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
Is there some setting that I've missed?   Some workaround that will let this proceed?
Eric Norum
[email protected]
Re: VDCT PostScript problem Eric Norum
Prev: EPICS Driver Needed Akridge, Charles S. (MSFC-ES52)
Next: seq pvPut to a waveform Dayle Kotturi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VDCT PostScript problem Eric Norum
ANJ, 08 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
