1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MOXA ARM computer and streamDevice
To: "Dirk Zimoch" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 4 Oct 2010 12:18:51 -0400
Hello Dirk,
For me using Moxa DA66x, there's no major problem in the cross
compiling, just need some configurations to build
cross-compiler(xscale_be) and EPICS base(i.e. specify
'CROSS_COMPILER_TARGET_ARCHS', 'GNU_DIR', etc.).
Yes, the NFS server is running on the Moxa box.
Another alternative for computer with multiple serial ports would be
Moxa DA-710 (http://www.moxa.com/product/DA-710.htm ). It's x86
processor and more powerful than little ARM. It comes with 4 Ethernet
ports and 2 RS-232. If need more serial ports, buy the 8-port
RS-232/422/485 expansion module cards (they have 'serial optical
isolation' version) and insert the modules into DA-710 PCI slots(~4).
DA-710 can be shipped with Debian/Linux on a hard-disk so that we can
take advantage of EPICS Debian packages(i.e. base, softioc, procserv,
iocstats, etc.) available from NSLS-2(http://epics.nsls2.bnl.gov/debian/
Cheers,
Yong
NSLS-II Controls Group
>-----Original Message-----
>From: Dirk Zimoch [mailto:[email protected]]
>Sent: Monday, October 04, 2010 8:57 AM
>To: Hu, Yong
>Cc: Martin Konrad; EPICS tech-talk
>Subject: Re: MOXA ARM computer and streamDevice
>Hello Yong,
>I am also interested in this issue.
>What is the problem in the cross compiling process?
>Can I use NFS on the DA66*?
>Are there other alternatives (i.e. 19" computers with many RS232/485
>ports)? So far I used a solution with an additional PC providing remote
>tty devices. But I like the idea of running EPICS directly on the
>machine with the ttys.
>Dirk
>Hu, Yong schrieb:
>> Hi Martin,
>> I played with Moxa DA662(2 more Ethernet ports than DA661) for a
while
>and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4).
>The cross compiler(linux-xscale_be) source code is from Moxa, but we
>rebuilt it. The whole cross compiling process takes some efforts. I can
>send you the static cross-complied executable(base, asyn and stream all
>included) if you want.
>> My application is to monitor 1-wire temperature sensors (~20K) for
>NSLS-2. We need 90 Moxa DA662, that's a big number. For better system
>maintenance and software development, I'm going to abandon Moxa DA-662
>and changing to use 5 powerful and stable servers(multiple cpu cores)
to
>handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that
>the Linux/Debian inside Moxa has limited tools/commands so that it's
>painful to use.
>> Hope you make a good decision.
>> Yong
RE: MOXA ARM computer and streamDevice Xu, Huijuan
MOXA ARM computer and streamDevice Martin Konrad
RE: MOXA ARM computer and streamDevice Hu, Yong
Re: MOXA ARM computer and streamDevice Dirk Zimoch
Prev: Re: MOXA ARM computer and streamDevice Dirk Zimoch
Next: RE: MOXA ARM computer and streamDevice Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
