1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error)
To: Jay Steele <[email protected]>
Cc: Claus Flachenecker <[email protected]>, Christian Roehrig <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 14 Oct 2010 17:21:04 -0500
Hi Jay,
we do use tpmac with EPICS-3.14.11. From your message it is hard
to tell what exactly is wrong in your case, but I suspect something
is messed with the Makefile or DBD files. In other words, I think
this is not a tpmac problem, but rather one caused by a mistake
in following synApps build rules.
It may help to look how we package our IOC compilation directories at
the GM/CA CAT. For that purpose I re-arranged the TPMAC distribution
to include six examples from the GM/CA CAT (two IOCs per each of
our three beamlines):
http://www.gmca.aps.anl.gov/TPMAC2/tpmac3-7.zip
These are:
synApps/xxx_gmca23b_ioc1
synApps/xxx_gmca23b_ioc2
Try to comply with the same build style. SynApps build system
is fragile and it is better to follow a good working example
as much as possible.
Hope it helps.
-- Sergey
On 10/13/2010 4:18 PM, Jay Steele wrote:
Hi Tech-Talk,
To use the TurboPMAC VME board with a PPC mother board to control
motors, I am trying to integrate tmac-3-7 with synApps_5_5 and
epics/base-3-14-11 for my IOC named 21idbnp. I am having the following
problem. Any clues to its resolution or a workaround would be greatly
appreciated.
tpmac-3-7 compiles with synApps. I added the statement
"ioc21idbnpVX_DBD+=pmacInclude.dbd" to 21idbnpApp/src/Makefile.
pmacInclude.dbd includes statusRecord.dbd, tsubRecord.dbd,
statusDevice.dbd, pmacAsynIPPort.dbd, pmacAsynMotor.dbd,
pmacAsynCoord.dbd, and add_pmac.dbd. Then I compile the 21idbnp IOC that
includes the tpmac libraries (pmacAsynCoord, pmacAsynIPPort,
pmacAsynMotor, pmacIoc). This compiles for vxWorks without error.
When I load the munch file to vxworks, I get the following error.
ld(0,0,"21idbnp.munch")
Undefined symbol: pvar_dset_devPmac (binding 1 type 0)
Undefined symbol: pvar_dset_devPmacRamStatus (binding 1 type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
value = 0 = 0x0
For my investigation, I see the following:
1. when compiling the IOC, -lpmacIoc, -lpmacAsynCoord, -lpmacAsynIPPort,
and -lpmacAsynMotor are used with ld to create 21idbnp.
2. grep using the string "pvar_dset_devPmac" in the IOC directory
results in the following:
a. binary file 21idbnp.munch matches.
b. ioc21idbnpVx_registerRecordDeviceDriver.cpp has references to
pvar_dset_devPmac.
c. binary file 21idbnp matches.
d. binary file ioc21idbnpVx_registerRecordDeviceDriver.o matches.
e. 21idbnp.nm has references to pvar_dset_devPmac.
3. Same results as #2 above for string "pvar_dset_devPmacRamStatus"
Jay Steele
XRadia Corporation
The information in this email, including any attachments, is
confidential and intended only for the recipient(s) listed. Any use of
this email for any other purpose is prohibited. If you have received
this email in error, please notify me immediately by reply email, delete
this email, and do not disclose its contents to anyone.
Prev: RE: slow caput from R3.14.11 client to R3.14.9 IOC Jeff Hill
Next: Problem in registerRecordDeviceDriver Xinyu Ao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Aerotech Ensemble home search problem Ron Sluiter
ANJ, 14 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
