1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem in registerRecordDeviceDriver
To: "Xinyu Ao" <[email protected]>, <[email protected]>
Date: Fri, 15 Oct 2010 06:50:52 -0500
What architecture are you running on?  Linux? vxWorks?  If it is Linux you can just enable core dumps
limit core 100000
Then when it crashes run gdb on the application and the core dump and see what where it crashed.  Or you can run the application directly with gdb.
Sent: Thu 10/14/2010 8:48 PM
To: [email protected]
Subject: Problem in registerRecordDeviceDriver
     I'm using PI C-863 Mercury motor controller to control PI M-126 stage under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
compiled successfully under EPICS version 3.14.11, with supported of packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
calc-2-8.  However we encountered an segmentation fault error in executing st.cmd when trying to run command of xxx_registerRecordDeviceDriver pdbbase.
    could anybody give me a hint on the problem!
   Thanks
   Xinyu Ao
  SSRF
Re: Problem in registerRecordDeviceDriver Ralph Lange
Re: Problem in registerRecordDeviceDriver Xinyu Ao
Prev: CSS XY Graph show/hide traces PaweÅ PrÄdki
Next: Re: Problem in registerRecordDeviceDriver Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem in registerRecordDeviceDriver Xinyu Ao
ANJ, 16 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
