1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error compiling sncseq-2.0.99 on MacOSX 10.6 (Snow Leopard) and possible patch (attached)
To: <[email protected]>
Date: Mon, 18 Oct 2010 11:33:01 +1100
When compiling the latest release of sncseq (2.0.99) on a MacOSX 10.6 (Snow Leopard) with EPICS base 3.14.11 the following error appears:
3 parsing conflicts.
../snl.re:20: error: redefinition of typedef ‘uint’
../types.h:40: error: previous declaration of ‘uint’ was here
make[3]: *** [lexer.o] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [snc.install] Error 2
make: *** [src.install] Error 2
Digging into the code I found two files (src/snc/snl.re and src/snc/types.h) defining uint as a new type unsigned int. On MacOSX (FreeBSD) that type is already defined in sys/types.h. I attached possible patch files that disable the re-definition of the uint type for Mac platforms. Please check if it is right, since these patch files only work on Mac and linux-x86_64 (debian lenny 64-bit), which are the platforms I can test. I haven't checked other FreeBSD platforms.
Cheers,
  Juan Carlos.
Attachment: snl.re.patch
Description: snl.re.patch
Attachment: types.h.patch
Description: types.h.patch
Juan Carlos Guzman
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]
Re: Error compiling sncseq-2.0.99 on MacOSX 10.6 (Snow Leopard) and possible patch (attached) Eric Norum
Prev: RE: CSS XY Graph show/hide traces Zhukov, Alexander P.
Next: RE: Eurotherm Temperature Controller Support emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Eurotherm Temperature Controller Support Stephen Lewis
Next: Re: Error compiling sncseq-2.0.99 on MacOSX 10.6 (Snow Leopard) and possible patch (attached) Eric Norum
ANJ, 18 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
