1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS XY Graph show/hide traces
To: TechTalk <[email protected]>
Date: Mon, 18 Oct 2010 15:41:14 +0200
Hi Sasha and Xihui,
That's one thing. Another is that the legend color changes as well. That may not be the worst thing but it happens.
However, in the SNS version of CSS, I get error popups when I try to define rules for the XY Graph widget. A lot of java null errors appear. This doesn't happen for other rules I implemented elsewhere.
Pawel Predki
W dniu 2010-10-17 19:21, Zhukov, Alexander P. pisze:
Hi Xihui,
I think making a trace the same color is background is not very good. Because while being invisible to human eye the trace will be considered when autoscaling Y axis.
Sasha
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Chen, Xihui
Sent: Friday, October 15, 2010 8:17 PM
To: PaweÅ PrÄdki; TechTalk
Subject: RE: CSS XY Graph show/hide traces
Hi Pawel,
I didn't give user the possibility to show/hide a trace, but it is possible. To add a "Visibility" property to every trace will make the property sheet longer, so I have to be careful. I think you can set the trace color same as the plot area background color to hide the trace. If there are more people asking the same function, I will add the "Visibility property to every trace.
Xihui
Sent: Friday, October 15, 2010 6:56 AM
To: TechTalk
Subject: CSS XY Graph show/hide traces
Hello,
Is it possible to dynamically show/hide traces according to some flag?
I have a maximum of four traces I want to display on an XY Graph but it
should be possible for the user to switch to 1 or 2 instead of 4.
Is there a way to do it dynamically in CSS or should I just write values
higher (lower) than the maximum (minimum) values of the given trace to
the PV that I don't want to be visible?
Cheers,
Pawel Predki
Technical University of Lodz,
Department of Microelectronics and Computer Science
CSS XY Graph show/hide traces PaweÅ PrÄdki
RE: CSS XY Graph show/hide traces Chen, Xihui
RE: CSS XY Graph show/hide traces Zhukov, Alexander P.
Prev: Manipulating time in records Di Maio Franck
Next: Re: Eurotherm Temperature Controller Support Stephen Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS XY Graph show/hide traces Zhukov, Alexander P.
Next: INLINK with PP and Asynchronous Device Support Schoeneburg, Bernd
ANJ, 18 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
