1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Lookup table problem
To: <[email protected]>
Cc: [email protected]
Date: Thu, 21 Oct 2010 11:37:57 +0100
We have done a similar thing at Diamond for our trim coil compensation.
We implemented a lookup table in a GenSub (in c). We have a number of
input parameters; the most significant one is Gap of course. We ended up
with a more complex table to support our helical undulators so that we
can compensate for the position of the phasing motion and whether we are
in circular or linear mode.
Our acc-phys group do some analysis on the machine to establish the
compensation table. This table is then written to a waveform pv via a
simple client tool. We then use BURT to maintain the operation of the
table. There is also Auto Save and Restore that might be useful.
Personally I am not so keen on reading from the filesystem as it is more
difficult to have version control than the EPICs tools provide.
I can send you the code if you are interested but the base algorithms
are quite simple.
Austen.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Silver
Sent: 21 October 2010 09:41
To: tech-talk
Subject: Lookup table problem
hi,
  I need to implement a function for insertion device like this:
  Read a two-dimensions table file from the disk, which is values for
gap positions and Correction coil power supplies (one gap value
corresponding to 4 power supply value). If a gap position is set from
the operator, four power supplies will be set automatically.
I want to use SNC language to do this, for reading the data from disk,
use an asub record for it. Is it ok? Is there any better ways? Did
anyone finish this job before?
  Any suggestions are appreciated.
Best regards
Geyang  2010-10-21
Lookup table problem Silver
Prev: Re: Manipulating time in records Marty Kraimer
Next: RE: Lookup table problem Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Lookup table problem Maren Purves
ANJ, 21 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
