1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04)
To: Matthieu Bec <[email protected]>
Cc: [email protected]
Date: Fri, 22 Oct 2010 14:56:03 +1100
On Thu, 2010-10-21 at 21:57 -0300, Matthieu Bec wrote:
> I had a similar problem with fedora, motif apps and newer release of
> xorg. Check if you have xorg-server updates where they patched the problem:
Thanks Matthieu. This was exactly the issue. It looks like the patch
only got accepted upstream a few months ago. I had xserver-xorg version
1:7.5+5ubuntu1. With some trepidation, I dist-upgraded my entire system
to Ubuntu 10.10. Now with xorg version 1:7.5+6ubuntu3, and it works
fine.
Thanks again for the amazingly swift assistance.
Angus
MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Angus Gratton
Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Matthieu Bec
Prev: Re: Lookup table problem Ben Franksen
Next: Client failed to connect to local server on VxWorks and Pharlap lorna . zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Matthieu Bec
ANJ, 22 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
