Rod,
I am basically trying to compile EPICS for the TS7370 (arm based arch).
How I achieve this is not important to me.
I looked at the TS cross toolchain.
I understand I am supposed to change my makefiles following
> CROSS = /opt/crosstool/gcc-3.3.4-glibc-2.3.2/bin/arm-linux-
> CC = $(CROSS)gcc
but how do I do that in EPICS?
I am not even sure how to correctly setup a target architecture...
export T_A=linux-arm; make
or even make T_A=linux-arm
seem to work.
My target EPICS_HOST_ARCH is linux-armv4l
My host is linux 64 bit.
It seems I need to create the files
CONFIG.linux-x86_64.armv4tl
CONFIG_SITE.linux-x86.linux-armv4tl
CONFIG.Common.linux-armv4tl
I copied ../configure/os/CONFIG...linux-arm... files to compile
But I run into several issues...
Is there any resource for cross compiling on EPICS?
Any other info on how you achieve to run epics on a TS7370 is welcome.
On 08:57 Mon 25 Oct , Rod Nussbaumer wrote:
> I have also been able to cross compile EPICS and other applications
> using the Technologics Systems cross toolchain, but am not using that
> for production work.
Emmanuel
- Re: EPICS on ARM (continued) emmanuel_mayssat
- Re: EPICS on ARM (continued) Dirk Zimoch
- RE: Thread model for EPICS on ARM CPU michael.abbott
- Re: Thread model for EPICS on ARM CPU Rod Nussbaumer
RE: EPICS CA problems Mark Rivers
<2010>
2025
Cross Compiling Linux for Embedded Systems Michael Abbott
<2010>
2025
