1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Some Channel Access Questions
To: [email protected]
Date: Wed, 27 Oct 2010 00:23:54 +0200
Hey Jeff
many thanks for the detailed (and prompt) answers. I am glad that there
are no artificial restrictions to be observed from the client side.
Interesting also to know what happens if you overload the server or the
client library although that is not the scenario I had in mind. I was
just concerned about 'collisions' when two or more threads occasionally
access the same channel at (about) the same time.
Some things are still a bit unclear to me:
> > What if I interleave a synchronous ca_get
> > (i.e. I wait for completion using ca_pend or somesuch) with a
> > ca_get or ca_get_callback issued by another thread?
> Only a thread which has initialized the library in
> non-preemptive callback mode can call ca_pend_io to
> rendezvous with completion of a batch of no-callback
> gets which have been requested;
I didn't know that. What happens if I do it anyway, i.e. call a regular
ca_get in preemptive callback mode twice in a row and then (try to)
wait for the result using ca_pend_io? (Same thread).
> furthermore, it's not
> allowed to attach additional threads to a non-preemptive
> callback mode ca context.
Yes, I knew that. So let's assume preemptive callback mode.
> So while one can mix ordinary get and callback get in
> a non-preemptive mode ca context, a preemptive mode ca
> context is a no-callback get free zone.
Wait, do I understand this right? How can I get a callback if I do plain
ca_get? Or did you mean: in preemptive callback mode plain ca_get (no
callback) is always blocking?
Cheers
ben
RE: Some Channel Access Questions Jeff Hill
Some Channel Access Questions Ben Franksen
Prev: RE: Some Channel Access Questions Jeff Hill
Next: Re: Some Channel Access Questions Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Some Channel Access Questions Jeff Hill
ANJ, 26 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
