Andrew Johnson wrote:
Yes, if you want to influence the rank of a particular idea you do have to
vote quite a lot for it to come up. Maybe that's not terribly efficient, but
until someone else finds or develops a better tool this is what we have to
work with right now.
As Lewis said, you have to keep voting if you want to vote for or against a
particular idea. If you don't like the way that an idea is worded, rewrite it
and submit your rewrite, if it's better it will get voted above the original.
http://www.allourideas.org/epics
the way this presents itself is a bit like "kitten war":
http://kittenwar.com/ - which can be an enormous time sink if
you let it draw you into that, only, voting for EPICS ideas
is something that may or may not determine all of our future
work, and some directions we're all likely to take.
I voted some 180 or so times (it only counts the votes where one picks
one over another, not the "can't decide" ones) when it started feeling
a bit repetitive, but the results are kind of interesting.
Maren
- EPICS Suggestions and Priorities Andrew Johnson
- Re: EPICS Suggestions and Priorities Ben Franksen
- Re: EPICS Suggestions and Priorities Andrew Johnson
MDrive - a novice in trouble James Rezende Piton
<2010>
<2010>
ANJ, 17 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
