Ok, Andrew, I will try your solution.
Now assuming that I need flex... how would I do that?
On 15:30 Tue 16 Nov , Andrew Johnson wrote:
> Hi Emmanuel,
> On Tuesday 16 November 2010 14:21:36 [email protected] wrote:
> > I am trying to compile the sequencer on arm.
> > I am using a cross toolchain.
> > I am apparently missing the flex library for the arm toolchain.
> You don't actually need it, someone added libfl as a dependent library
> incorrectly (or maybe it was added a very long time ago before we included a
> copy of flex in Base).
> > Is there a way to install the flex library for arm on my linux 64b?
> Edit src/snc/Makefile and delete all of the SYS_PROD_LIBS_* lines from it.
> You may also have to change the line
> PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
> into
> PROD_LIBS += $(EPICS_BASE_HOST_LIBS)
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
Emmanuel
- Re: Cross-compilation missing library Andrew Johnson
- Cross-compilation missing library emmanuel_mayssat
<2010>
2025
<2010>
2025
