1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: How to shutdown/restart a soft-ioc from a (watchdog) record
Cc: [email protected]
Date: Thu, 18 Nov 2010 09:02:00 +0100
Am 17.11.2010 um 17:30 schrieb Andrew Johnson:
> Hi Burkhard,
> On Wednesday 17 November 2010 05:03:06 Burkhard Kolb wrote:
>> How do I properly exit a soft-ioc when a record detects some malfunction?
>> I tried epicsExit(), but that does not work from the subRecord which I
>> trigger form a calcout record.
> What does the epicsExit() call do when you use it?  That is how you're meant
> to shut down the IOC, but there may be drivers running which haven't properly
> registered an epicsAtExit() routine to stop their background threads, which
> can result in the process not stopping properly.  What extra code are you
> including in the IOC?
The extra code is a library which uses RPC (sun...) to communicate. This is also the
component which apparently hangs until there is a "RPC Timeout" which actually takes
pretty long.
When the epicsExit call is executed the IOC hangs, the clients report after some
time the connection loss, but procServ does not restart the IOC because it's not completely
exited yet.
Burkhard
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Re: How to shutdown/restart a soft-ioc from a (watchdog) record Ralph Lange
RE: How to shutdown/restart a soft-ioc from a (watchdog) record Al Honey
How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
Re: How to shutdown/restart a soft-ioc from a (watchdog) record Andrew Johnson
Prev: Anyone tried connecting a client to a local server on vxWorks 6.3? lorna . zhang
Next: Re: How to shutdown/restart a soft-ioc from a (watchdog) record Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: How to shutdown/restart a soft-ioc from a (watchdog) record Andrew Johnson
ANJ, 18 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
