I'm testing the 3.14.12 release! Here is the diff of config that I've changed: --- ../base-3.14.12.org/configure/CONFIG_SITE 2010-11-24 21:54:36.000000000 +0100 +++ ../base-3.14.12/configure/CONFIG_SITE 2010-11-25 10:20:52.809374249 +0100 @@ -169,6 +169,9 @@ # define INSTALL_LOCATION here #INSTALL_LOCATION=<fullpathname> +# Hinko, Thu Nov 25 08:35:13 CET 2010 +INSTALL_LOCATION=$(TOP)/../install + # Use POSIX thread priority scheduling (YES or NO) USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO diff -urN -x 'O.*' ../base-3.14.12.org/configure/RELEASE ../base-3.14.12/configure/RELEASE --- ../base-3.14.12.org/configure/RELEASE 2010-11-24 21:54:36.000000000 +0100 +++ ../base-3.14.12/configure/RELEASE 2010-11-25 10:47:01.000000000 +0100 @@ -19,3 +19,11 @@ # RELEASE.Common.$(T_A) # RELEASE.$(EPICS_HOST_ARCH).$(T_A) +# Hinko, Thu Nov 25 08:35:13 CET 2010 +INSTALL_LOCATION_EXTENSIONS=$(TOP)/../../install + +# Hinko, Thu Nov 25 08:35:13 CET 2010 +# If EPICS_BASE is set here base compilation fails.. +#EPICS_BASE=$(TOP)/../../install + +EPICS_EXTENSIONS=$(TOP) Example IOC was created with: $ makeBaseApp.pl -t example evgen $ makeBaseApp.pl -i -t example evgen $ make make -C ./configure install make[1]: Entering directory `/home/hinko/work/epics/evgen/configure' make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install make[2]: Entering directory `/home/hinko/work/epics/evgen/configure/O.linux-x86' perl /home/hinko/work/epics/install/bin/linux-x86/convertRelease.pl checkRelease EPICS/Release.pm: Circular definition of macro TOP make[2]: *** [checkRelease] Error 2 make[2]: Leaving directory `/home/hinko/work/epics/evgen/configure/O.linux-x86' make[1]: *** [install.linux-x86] Error 2 make[1]: Leaving directory `/home/hinko/work/epics/evgen/configure' make: *** [configure.install] Error 2
http://www.i-tech.si - When your users demand stability The information transmitted is intended solely for the addressee and may contain confidential and/or privileged information. Any review, retention, disclosure or other use by persons other than the intended recipient is prohibited. If you received this in error, please notify the sender and delete all copies.
ANJ, 29 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
