1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EDM installing problems on linux-x86
To: Saed Abu Ghannam <[email protected]>
Date: Mon, 06 Dec 2010 14:46:50 +0100
Hi Saed,
the first thing to try could be look where Xm.h should be into your machine...
-if you find that you have to adjust the epics/extensions/configure/os/CONFIG_SITE.xxxxxx
-if you didn't find that you may search which package could contain that (i.e. into RedHat Linux: "yum provides Xm.h")
I believe that should be into openmotif-devel _or_ lesstif-devel
Hope this helps
-Mauro
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Tel. +39.049.8068558
Fax. +39.049.641925
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the scratch in ITALY is in production since begin 2010!!
On 12/6/2010 2:21 PM, Saed Abu Ghannam wrote:
I am new with EPICS am trying to install EDM and the below error keeps appearing.
[root@sesame-10-1-22-37 edm]# make
make -C ./util install
make[1]: Entering directory `/home/MyEpics/extensions/src/edm/util'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/home/MyEpics/extensions/src/edm/util/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/MyEpics/extensions/src/edm/util/O.linux-x86'
make[1]: Leaving directory `/home/MyEpics/extensions/src/edm/util'
make -C ./lib install
make[1]: Entering directory `/home/MyEpics/extensions/src/edm/lib'
make[2]: Entering directory `/home/MyEpics/extensions/src/edm/lib/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -DSINGLE_THREADED=1 -D__epics__=1  -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I../../../../../base/include/os/Linux -I../../../../../base/include  -I../../../../include       -I../../util -I../../lib -I/usr/include -I/usr/include/X11    ../clipbd.cc
../clipbd.cc:19:19: error: Xm/Xm.h: No such file or directory
../clipbd.cc: In member function ‘void clipBdClass::clipbdInit(_WidgetRec*)’:
../clipbd.cc:46: error: ‘xmPrimitiveWidgetClass’ was not declared in this scope
../clipbd.cc:50: error: ‘XmNuserData’ was not declared in this scope
../clipbd.cc: In function ‘Boolean ConvertSelection(_WidgetRec*, Atom*, Atom*, Atom*, void**, long unsigned int*, int*)’:
../clipbd.cc:117: error: ‘XmNuserData’ was not declared in this scope
../clipbd.cc:126: warning: dereferencing type-punned pointer will break strict-aliasing rules
make[2]: *** [clipbd.o] Error 1
make[2]: Leaving directory `/home/MyEpics/extensions/src/edm/lib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/home/MyEpics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
any suggestions ?
Best Regards,
Saed Abu Ghannam.
EDM installing problems on linux-x86 Saed Abu Ghannam
Prev: Re: EDM installing problems on linux-x86 Hinko Kocevar
Next: Re: New StreamDevice version Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Base-3.14.12 (win32) on win 7 64 bit system compilation Andrew Johnson
ANJ, 07 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
