Thanks Eric. I will try the patch later. Best regards, Jim Hytec Electronics Ltd. Tel: +44 (0) 118 975 7770 Fax: +44 (0) 118 975 7566 Web: www.hytec-electronics.co.uk Incorporated in England No 1246940 VAT NO GB 285 2479 27 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ From: Eric Norum [mailto:[email protected]] Sent: 09 December 2010 17:21 To: Daron Chabot Cc: Jim Chen; EPICS Tech Talk Subject: Re: rtems-4.10 tftp support --- /usr/local/epics/R3.14.12/base/src/RTEMS/base/rtems_init.c 2010-11-24 12:54:36.000000000 -0800 +++ rtems_init.c 2010-12-09 09:18:34.270548000 -0800 printf ("***** Initializing TFTP *****\n"); +#if __RTEMS_MAJOR__>4 || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__>9) || (__RTEMS_MAJOR__==4 && __RTEMS_MINOR__==9 && __RTEMS_REVISION__==99) + mount_and_make_target_path(NULL, + RTEMS_FILESYSTEM_TYPE_TFTPFS, + RTEMS_FILESYSTEM_READ_WRITE, rtems_bsdnet_initialize_tftp_filesystem (); if (!hasLocalFilesystem) { On Dec 9, 2010, at 9:06 AM, Daron Chabot wrote:
Hi Jim,
Have a look at tftpTest/init.c from the RTEMS network-demos (cvs HEAD):
cvs -d :pserver:[email protected]:/usr1/CVS co network-demos
It looks like the new initialization steps are:
rtems_bsdnet_initialize_network (); mount_and_make_target_path( NULL, "/TFTP", RTEMS_FILESYSTEM_TYPE_TFTPFS, RTEMS_FILESYSTEM_READ_WRITE, NULL );
Patches to Base welcome :-)
-- dc On Thu, Dec 9, 2010 at 11:26 AM, Jim Chen <[email protected]> wrote: Eric,
It seems like that rtems-4.10 has changed some function prototypes in tftpDriver.c code such as rtems_bsdnet_initialize_tftp_filesystem (doesn't exist anymore) which fails the build of EPICS3.14.11/12 that doesn't use NFS (with OMIT_NFS_SUPPORT defined). Is there a particular reason for this and how can I get around with this please?
Best regards,
- Asyn VXI-11 Driver and VXI-11 Locking William Lu
- Re: Asyn VXI-11 Driver and VXI-11 Locking Eric Norum
- Re: Asyn VXI-11 Driver and VXI-11 Locking William Lu
- Re: rtems-4.10 tftp support Daron Chabot
- Re: rtems-4.10 tftp support Eric Norum
asyn R4-15 available Mark Rivers
<2010>
2025
<2010>
2025
ANJ, 09 Dec 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
