1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: sscan and averaging [SEC=UNCLASSIFIED]
To: Damien LYNCH <[email protected]>
Cc: [email protected]
Date: Fri, 14 Jan 2011 02:26:10 -0600 (CST)
Damien,  You could do that, but there is software in the calc
module specifically for this kind of application.  userAve10.db
is (ten copies of) a sub-record based averaging database (much of
which I stole from Frank Lenkszus) that you can attach at run time to
any PV whose value you want to average.
The averaging algorithm can easily be triggered by a sscan record,
because it declares completion only after a user specified number of
samples have been averaged.  There is some (skimpy) documentation in
http://www.aps.anl.gov/bcda/synApps/calc/R2-8/calcDocs.html
The MEDM display is also intended to sort of show you how to use it.
To setup the averaging, set xxx:userAve1.INPB = "<your PV> CP"
(assuming <your PV> is periodically processed by some other entity).
For scanning, set the xxx:userAve1_mode to "ONE-SHOT", have the
sscan record write '1' to xxx:userAve1_acquire with a detector
trigger, and have it read the averaged value from xxx:userAve1.VAL.
Tim
----- Original Message -----
To: [email protected]
Sent: Thursday, January 13, 2011 7:00:44 PM
Subject: sscan and averaging [SEC=UNCLASSIFIED]
We have a sscan record setup to allow operators to scan over a sample in an ion source. Currently the data read at each scan position is whatever the detector is reading at that instant. We would like to acquire several times at each position and take the average. What is the best way of doing this? Should I set up a multidimensional scan and set the ACQM field in the inner sscan record to ACCUMULATE and perform the averaging elsewhere after the scan is finished?
Damien Lynch
Accelerator IT Systems Engineer
Institute of Environmental Research
Australian Nuclear Science and Technology Organisation
Locked Bag 2001 Kirrawee DC NSW 2232
Important: This transmission is intended only for the use of the addressee. It is confidential and may contain privileged information or copyright material. If you are not the intended recipient, any use or further disclosure of this communication is strictly forbidden. If you have received this transmission in error, please notify me immediately by telephone and delete all copies of this transmission as well as any attachments.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
sscan and averaging [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: sscan and averaging [SEC=UNCLASSIFIED] LYNCH, Damien
Next: VMEbus ACFAIL* glitch causes OMS VME58 reboot Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
