1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn R4-16 available
To: <[email protected]>, <[email protected]>
Date: Mon, 17 Jan 2011 15:14:45 -0600
Folks,
asyn R4-16 is now available.  Links to the new documentation, release notes and tar file can be found here:
http://www.aps.anl.gov/epics/modules/soft/asyn/
asyn is now also available via the APS Subversion repository here:
https://svn.aps.anl.gov/epics/asyn/
This is from the release notes:
drvAsynIPPort
Support has been added for terminal servers which support the TELNET RFC 2217 protocol. To communicate with such devices specify "COM" as the protocol in the drvAsynIPPortConfigure command. This allows port parameters (speed, parity, etc.) to be set using an asynRecord or asynSetOption commands just as for local serial ports.
drvVxi11
Fix from Benjamin Franksen to fix problem with reconnection.
The 'timeout' argument to vxi11Configure has been changed from double to string. This allows vxi11Configure to be called directly from the vxWorks shell.
Prev: GigE driver for Area Detector tom.cobb
Next: StreamDevice/ASYN connection to a Telnet port John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: GigE driver for Area Detector Eric Norum
