1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StreamDevice/ASYN connection to a Telnet port
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Mon, 17 Jan 2011 15:35:33 -0600
This is the code in asyn drvAsynIPPort.c readIt() function:
    thisRead = recv(tty->fd, data, maxchars, 0);
    if (thisRead > 0) {
        asynPrintIO(pasynUser, ASYN_TRACEIO_DRIVER, data, thisRead,
                   "%s read %d\n", tty->IPDeviceName, thisRead);
        tty->nRead += thisRead;
So the socket recv() function is only returning a single character.
That's not how most devices work, most send multiple characters in a
single message.  But you are presumably using the asynInterposeEos
layer, which repeatedly calls drvAsynIPPort::readIt() until it detects a
terminator, EOM, timeout, or the requested maximum number of characters.
-----Original Message-----
[mailto:[email protected]] On Behalf Of John Dobbins
Sent: Monday, January 17, 2011 3:23 PM
To: EPICS Tech-Talk
Subject: StreamDevice/ASYN connection to a Telnet port
Dear All,
I am connecting to a Gamma Vacuum SPCe ion pump power supply. This
device has an ethernet port which accepts telnet connections.
I set up StremDevice to communicate with it on port 23,
I have  asyn Trace Masks set as follows:
asynSetTraceMask("SPCe",-1,0x09)
asynSetTraceIOMask("SPCe",-1,0x2
I have a problem in that the response string , which I expect to look
like  "OK 00 7.90E-13 TORR"
appears like this:
epics> 2011/01/17 16:14:55.995 172.18.32.21:23 write 7
spc 0B\r
2011/01/17 16:14:56.475 172.18.32.21:23 read 1
O
K
0
0
2011/01/17 16:14:56.476 172.18.32.21:23 read 1
7
9
2011/01/17 16:14:56.477 172.18.32.21:23 read 1
0
E
1
2011/01/17 16:14:56.478 172.18.32.21:23 read 1
3
T
O
R
2011/01/17 16:14:56.479 172.18.32.21:23 read 1
R
\r
Can someone tell me what is going on here?
Regards and thanks,
John Dobbins
Cornell University
Lab for Elementary Particle Physics
StreamDevice/ASYN connection to a Telnet port John Dobbins
Prev: RE: StreamDevice/ASYN connection to a Telnet port Mark Rivers
Next: Spilt the waveform by different indices in DB 勇克
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: StreamDevice/ASYN connection to a Telnet port Dirk Zimoch
