Hi Julia,
On Tuesday 18 January 2011 15:52:18 Zhang, Jihong (Julia) wrote:
> I have a question on the trailing zeros. why does caget report trailing
> zeros; is this a bug?
No it's normal, but you can prevent it.
> caget subArr1
> subArr1 16 1 2 3 4 0 0 0 0 0 0 0 0 0 0 0 0
> /* I only need the first 4 numbers, no training 0 */
If you know you only need 4 elements and don't want the trailing zeros you
should only request 4:
caget -# 4
subArr1 4 1 2 3 4
Alternatively if you're using Base version 3.14.12 you can make use of the new
dynamic array sizing feature to request just the elements that are currently
defined, like this:
caget -c subArr1
subArr1 4 1 2 3 4
The latter approach allows you to change the number of elements on the IOC
without having to change your client code, but it only works with both 3.14.12
IOCs and CA clients.
Zenon Szalata wrote:
> Looks like you have dimensioned your subArrays to have 16 elements. caget
> reports all 16 values even if only first four have been populated.
A subArray record usually has to have MALM configured large enough to hold the
whole waveform, so she has no choice about that.
Note that the behavior of the subArray record type was changed slightly in the
3.14.10 release; earlier versions did not implement one of the record support
interface routines correctly. They were reporting the maximum number of
elements for the VAL field as NELM, so against an IOC before 3.14.10 the
cagets above would only have displayed 4 elements. Unfortunately since NELM
can be changed at runtime that could cause some clients to crash.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- About subArray trailing zeros Zhang, Jihong (Julia)
Re: Building base-3.14.12 for a specific target J. Lewis Muir
Problem exiting IOC Vigder, Mark
<2011>
2025
RE: About subArray trailing zeros Szalata, Zenon M.
LabVIEW-to-Epics-interface for Linux and Windows - CA Lab Carsten Winkler (HZB)
<2011>
2025
