1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CSS BOY Meter widget limits
To: Paweł Prędki <[email protected]>, TechTalk <[email protected]>
Date: Tue, 25 Jan 2011 09:20:02 -0500
Hello:
Recent EPICS releases changed the IOC code such that alarm limits that are
not defined show up as NaN. Before, uninitialized alarm or display limits
showed up as 0 (zero).
For example, you can set only the HIGH and HIHI, but not LOW and LOLO, and
then the 'Show PV Info' action will display NaN for the uninitialized
alarm_low, warn_low, but reflect the configured values for alarm_high and
warn_high.
The latest version of BOY should properly handle that and ignore such NaN
limits. We may have to update the release notes to make it obvious what
version introduced the fix.
-Kay
On 1/25/11 06:27 , "Paweł Prędki" <[email protected]> wrote:
> Hi,
> I'm having problems with the meter widget, specifically with the 'Limits
> from PV' property. Although the lower and upper range limits are loaded
> correctly according to the database record the HIGH, LOW, HIHI and LOLO
> values are not loaded at all.
> The 'Show PV Info' action available in runtime mode displays NaN for
> alarm_low, warn_low, alarm_high and warn_high.
> Any ideas what could be the cause of this behaviour?
> Cheers,
> Pawel Predki
Re: CSS BOY Meter widget limits Kasemir, Kay
Re: CSS BOY Meter widget limits Paweł Prędki
Prev: Re: gensub/asub inputs not PP Andy Foster
Next: Re: CSS BOY Meter widget limits Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: CSS BOY Meter widget limits Paweł Prędki
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
