What if you change "Raw Soft Channel" to "Soft Channel". Normally one would use quotes around the values, right?
field(HIHI,"8.0")
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pawel Predki
Sent: Tuesday, January 25, 2011 9:44 AM
To: Kasemir, Kay
Cc: TechTalk
Subject: Re: CSS BOY Meter widget limits
W dniu 2011-01-25 16:24, Kasemir, Kay pisze:
> Hello:
> On 1/25/11 10:17 , "Paweł Prędki"<[email protected]> wrote:
>> The thing is the HIHI, HIGH, LOW and LOLO values are initialized in the
>> record but BOY doesn't seem to be loading them. The record I'm referring
>> to is as follows:
>> record(ao,DISK:FORWARDING") {
>> field(DESC,"Forwarding Throughput")
>> field(DTYP,"Raw Soft Channel")
>> field(EGU,"Gbps")
>> field(OMSL,"supervisory")
>> field(DRVL,0.0)
>> field(DRVH,10.0)
>> field(LOPR,0.0)
>> field(HOPR,10.0)
>> field(HIHI,8.0)
>> field(HIGH,7.0);
>> field(LOW, 1.0);
>> field(LOLO,0.0)
> Not sure about the quotes in this example.
> Does the IOC load the database without errors?
> Try caget to read the value as a DBR_CTRL_DOUBLE:
> caget -d 34 DISK:FORWARDING
> It should also show NaN (actually nan) for fields that the IOC reports as
> not initialized.
> -Kay
Hello,
You are right - I get nan for the lo/hi warn/alarm fields using caget.
It doesn't matter if I use the quotes or not. The IOC doesn't display
any errors when loading this db.
Does the fact that the native data type is DBF_DOUBLE have anything to
do with it? I wonder why only those four fields are invalid in this case.
Pawel
- Re: CSS BOY Meter widget limits Kasemir, Kay
- Re: CSS BOY Meter widget limits Paweł Prędki
Re: CSS BOY Meter widget limits Andrew Johnson
<2011>
2025
<2011>
2025
