1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: GigE driver for Area Detector
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Jan 2011 08:40:40 -0800
Hi Tom,
Here is a complete console output:
zms@ar-esaux1 $ ./st.cmd
#!../../bin/linux-x86/example
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocexample")
epicsEnvSet("TOP","/afs/slac/g/testfac/workspace/zms/rhel5/R3.14.11/ioc/aravisnew/aravisGigE-0-1-2/iocs/example")
epicsEnvSet("EPICS_SITE_TOP","/afs/slac/g/testfac/rhel5/epics/R3.14.11")
epicsEnvSet("EPICS_BASE","/afs/slac/g/testfac/rhel5/epics/R3.14.11/base")
cd "/afs/slac/g/testfac/workspace/zms/rhel5/R3.14.11/ioc/aravisnew/aravisGigE-0-1-2/iocs/example"
epicsEnvSet "EPICS_TS_MIN_WEST", '0'
# Loading libraries
# Device initialisation
dbLoadDatabase "dbd/example.dbd"
example_registerRecordDeviceDriver(pdbbase)
# aravisCameraConfig(portName, cameraName, maxBuffers, maxMemory)
#aravisCameraConfig("CAM1", "Prosilica-02-2166A-06844", 50, -1)
aravisCameraConfig("CAM1", "Basler-20913924", 50, -1)
Looking for camera 'Basler-20913924'... Found 0x8f23500
# NDStdArraysConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, maxMemory)
NDStdArraysConfigure("ARR1", 2, 0, "CAM1", 0, -1)
# Final ioc initialisation
dbLoadRecords 'db/example_expanded.db'
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Dec 10 2010
2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_EXPAUTOTARGET
ARAVISCAM1:CAM:ExpAutoTarget_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_GAINAUTOTARGET
ARAVISCAM1:CAM:GainAutoTarget_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_IRISAUTOTARGET
ARAVISCAM1:CAM:IrisAutoTarget_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_IRISVIDEOLEVELMAX
ARAVISCAM1:CAM:IrisVideoLevelMax_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_IRISVIDEOLEVELMIN
ARAVISCAM1:CAM:IrisVideoLevelMin_RBV devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisVideoLevel_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.726 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_EXPAUTOTARGET
ARAVISCAM1:CAM:ExpAutoTarget devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.726 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_GAINAUTOTARGET
ARAVISCAM1:CAM:GainAutoTarget devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.726 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_IRISAUTOTARGET
ARAVISCAM1:CAM:IrisAutoTarget devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.726 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_EXPAUTOALG
ARAVISCAM1:CAM:ExpAutoAlg_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.727 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_IRISAUTO
ARAVISCAM1:CAM:IrisAuto_RBV devAsynInt32::initCommon drvUserCreate
2011/01/26 17:18:55.727 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ARAVIS_EXPAUTOALG
ARAVISCAM1:CAM:ExpAutoAlg devAsynInt32::initCommon drvUserCreate
ARAVISCAM1:CAM:IrisAuto devAsynInt32::initCommon drvUserCreate
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 41779,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics>
Thanks again,
Zen
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Thursday, January 27, 2011 12:52 AM
> To: Szalata, Zenon M.; [email protected]; [email protected]
> Cc: [email protected]
> Hi,
> Could you attach the complete list of errors at startup please? The ones
> that I see so far are because the camera doesn't support the same
> feature set as the prosilica. From your XML file, the following are
> supported:
> Gain
> Gain Mode
> Exposure
> White Balance (manual mode may not work properly as the camera also
> allows setting of the green channel)
> All the standard areaDetector parameters supported by aravis
> The following won't work:
> Iris
> Exposure algorithm
> Any "Auto target" values
> If you copy aravisProsilica.template to aravisBasler.template and remove
> the offending records then it won't print the messages. It looks like
> aravis can talk to your camera, just not some of the features.
> Thanks,
> Tom Cobb,
> Diamond Light Source Ltd.
> Diamond House
> Harwell Science and Innovation Campus
> Didcot
> Oxfordshire
> OX11 0DE
> Tel +44 (0) 1235 778582
> > From: Szalata, Zenon M. [mailto:[email protected]]
> > Sent: 27 January 2011 01:26
> > To: Cobb, Tom (DLSLtd,RAL,DIA); [email protected]; Rees, Nick
> > (DLSLtd,RAL,DIA)
> > I have kludged a st.cmd file and when I run example with my st.cmd the
> camera
> > is found.  However, then I get many messages which I interpret as
> error
> > messages.  Here are some of them:
> NDArrayPort,
> > cd
> gE-
> > 0-1-2/iocs/example"
> > iocInit
> > Starting iocInit
> find
> drvUserCreate
> find
> drvUserCreate
> find
> drvUserCreate
> find
> drvUserCreate
> find
> drvUserCreate
> find
> drvUserCreate
> find
> find
> drvUserCreate
> find
> find
> > Is it fair to say that aravis as it now is, can't communicate with the
> camera?
> > I have attached an xml dump from the camera.
> > Thanks,
> > Zen
> > > From: [email protected] [mailto: [email protected]]
> > > Sent: Wednesday, January 26, 2011 12:45 PM
> > > To: [email protected]; Szalata, Zenon M.;
> [email protected];
> > > [email protected]
> > > Mark is right. We pass the .cmd file through MSI to generate the
> boot
> > > file. The rule is:
> > > %.boot: ../%.cmd
> > >         $(MSI) $(SYS_BOOT_FLAGS) $(USR_BOOT_FLAGS) $< > $@
> > > This is so we can have identical startup scripts for different
> > > architectures.
> > > However, in this one off case, it should be easy enough to edit the
> .cmd
> > > file and manually substitute the macros.
> > > Cheers
> > > Nick Rees
> > > Principal Software Engineer           Phone: +44 (0)1235-778430
> > > Diamond Light Source                  Fax:   +44 (0)1235-446713
> > > > From: [email protected] [mailto:tech-talk-
> > > > [email protected]] On Behalf Of Mark Rivers
> > > > Sent: 26 January 2011 19:35
> > > > To: Szalata, Zenon M.; Cobb, Tom (DLSLtd,RAL,DIA); tech-
> > > > [email protected]
> > > > I think they generate their startup files from a script.  You
> probably
> > > > need to manually create an st.cmd file based on their template.
> > > > [mailto:[email protected]] On Behalf Of Szalata, Zenon
> M.
> > > > Sent: Wednesday, January 26, 2011 1:33 PM
> > > > To: [email protected]; [email protected]
> > > > Hi Tom,
> > > > I downloaded the tar file from the link below.
> > > > I am having trouble building the examples.  I get this error:
> > > > make[4]: Entering directory
> `/afs/slac.stanford.edu/g/testfac/vol4/workspace/zms/rhel5/R3.14.11/ioc
> aravisnew/aravisGigE-0-1-2/iocs/example/iocBoot/iocexample/O.linux-x86'
> > > > Installing created file ../../../bin/linux-x86/../stexample.sh
> > > > make[4]: *** No rule to make target
> > > > `../../../bin/linux-x86/stexample.boot', needed by `buildInstall'.
> > > > Stop.
> > > > I can't find stexample.boot file.  Is it perchance stexample.src?
> > > > Anyway, the file tree structure you are using is different from
> what I
> > > > am used to and right now I feel a bit at a loss.
> > > > Thank you,
> > > > Zen
> > > > > Sent: Monday, January 17, 2011 9:53 AM
> > > > > Cc: [email protected]; Szalata, Zenon M.
> > > > > Subject: GigE driver for Area Detector
> > > > > Hi all,
> > > > > As a couple of people have asked for it, I've made a preliminary
> > > > release
> > > > > of the my areaDetector driver for GigE cameras on Linux based on
> the
> > > > > aravis library. It is only tested on Prosilica/AVT cameras,
> although
> > > > it
> > > > > should work with all GigE vision compliant cameras but, as
> always,
> > > > some
> > > > > cameras are more compliant than others...
> > > > > http://controls.diamond.ac.uk/downloads/support/aravisGigE
> > > > > Once you have built the module, there are 2 helper programs in
> the
> > > > > bin/linux-x86 directory, arv-show-devices will list all the GigE
> > > > vision
> > > > > cameras visible on the network, and dumpXml will dump their
> Genicam
> > > > xml
> > > > > files to disk. Please email me the outputs of these 2 programs
> if
> > > > your
> > > > > camera doesn't work properly.
> > > > > Thanks,
> > > > > Tom Cobb,
> > > > > Diamond House
> > > > > Didcot
> > > > > Oxfordshire
> > > > > OX11 0DE
> > > > > This e-mail and any attachments may contain confidential,
> copyright
> > > > and or
> > > > > privileged material, and are for the use of the intended
> addressee
> > > > only. If you
> > > > > are not the intended addressee or an authorised recipient of the
> > > > addressee
> > > > > please notify us of receipt by returning the e-mail and do not
> use,
> > > > copy, retain,
> > > > > distribute or disclose the information in or attached to the
> e-mail.
> > > > > Any opinions expressed within this e-mail are those of the
> > > individual
> > > > and not
> > > > > necessarily of Diamond Light Source Ltd.
> > > > > Diamond Light Source Ltd. cannot guarantee that this e-mail or
> any
> > > > > are free from viruses and we cannot accept liability for any
> damage
> > > > which you
> > > > > may sustain as a result of software viruses which may be
> transmitted
> > > > in or with
> > > > > the message.
> > > > > Diamond Light Source Limited (company no. 4375679). Registered
> in
> > > > England
> > > > > and Wales with its registered office at Diamond House, Harwell
> > > > Science
> > > > and
> > > > > Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> > > This e-mail and any attachments may contain confidential, copyright
> and or
> > > privileged material, and are for the use of the intended addressee
> only. If
> > you
> addressee
> > > please notify us of receipt by returning the e-mail and do not use,
> copy,
> > retain,
> > > distribute or disclose the information in or attached to the e-mail.
> individual and
> > not
> > > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > > are free from viruses and we cannot accept liability for any damage
> which
> > you
> > > may sustain as a result of software viruses which may be transmitted
> in or
> > with
> > > the message.
> > > Diamond Light Source Limited (company no. 4375679). Registered in
> England
> Science and
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If you
> are not the intended addressee or an authorised recipient of the addressee
> please notify us of receipt by returning the e-mail and do not use, copy, retain,
> Any opinions expressed within this e-mail are those of the individual and not
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or with
> the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
RE: GigE driver for Area Detector Mark Rivers
GigE driver for Area Detector tom.cobb
RE: GigE driver for Area Detector Szalata, Zenon M.
RE: GigE driver for Area Detector nick.rees
RE: GigE driver for Area Detector tom.cobb
Prev: RE: GigE driver for Area Detector tom.cobb
Next: RE: GigE driver for Area Detector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
