If multiple threads block on the same event then the current
implementation (posix) may spuriously wake up more than
one thread as a result of epicsEventSignal().
This is because the underlying pthread_cond_signal()/pthread_cond_wait()
explicitly have these same semantics.
IMO it would be a good idea to change epicsEventWait and
epicsEventWaitWithTimeout so that they handle this possible
case (and yield the same semantics as the RTEMS and vxWorks
variants).
-- Till
*** base-3-14-12/src/libCom/osi/os/posix/osdEvent.c.orig 2011-01-28 19:49:39.345588580 -0600
--- base-3-14-12/src/libCom/osi/os/posix/osdEvent.c 2011-01-28 19:51:58.901443789 -0600
*** 133,139 ****
status = mutexLock(&pevent->mutex);
checkStatusQuit(status,"pthread_mutex_lock","epicsEventWait");
/*no need for while since caller must be prepared for no work*/
! if(!pevent->isFull) {
status = condWait(&pevent->cond,&pevent->mutex);
checkStatusQuit(status,"pthread_cond_wait","epicsEventWait");
--- 133,139 ----
! while (!pevent->isFull) {
*** 151,157 ****
checkStatusQuit(status,"pthread_mutex_lock","epicsEventWaitWithTimeout");
convertDoubleToWakeTime(timeout,&wakeTime);
status = condTimedwait(
&pevent->cond,&pevent->mutex,&wakeTime);
--- 151,157 ----
! while (!pevent->isFull && 0 == status) {
- RE: epicsEvent (posix implementation) bug ? james.rowland
- Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
Motor driver for Parker Hannifin ACR series controllers? Mark Rivers
<2011>
2025
RE: ca_create_subscription element count Jeff Hill
<2011>
2025
