I think that this is the result of the device (stupidly and inefficiently) sending one character per IP packet.
On Feb 2, 2011, at 7:30 AM, Dirk Zimoch wrote:
> Hi John,
> StreamDevice normally reads first a single byte and then the rest in chunks of up to 63 bytes. The reason is that the first byte uses a different timeout (ReplyTimeout) than the others (ReadTimeout). The rest is fetched in 63 bytes chunks because I use an internal buffer of 64 bytes and want to be able to add a null byte at the end to avoid problems with some debug output.
> So the first "read 1" is normal. What surprises me are the other lines.
> When you switch on debugging in StreamDevice (var streamDebug 1), what do you see?
> Dirk
> John Dobbins wrote:
>> Dear All,
>> I am connecting to a Gamma Vacuum SPCe ion pump power supply. This device has an ethernet port which accepts telnet connections.
>> I set up StremDevice to communicate with it on port 23,
>> I have asyn Trace Masks set as follows:
>> asynSetTraceMask("SPCe",-1,0x09)
>> asynSetTraceIOMask("SPCe",-1,0x2
>> I have a problem in that the response string , which I expect to look like "OK 00 7.90E-13 TORR" appears like this:
>> epics> 2011/01/17 16:14:55.995 172.18.32.21:23 write 7
>> spc 0B\r
>> 2011/01/17 16:14:56.475 172.18.32.21:23 read 1
>> O
>> K
>> 0
>> 0
>> 2011/01/17 16:14:56.476 172.18.32.21:23 read 1
>> 7
>> 9
>> 2011/01/17 16:14:56.477 172.18.32.21:23 read 1
>> 0
>> E
>> 1
>> 2011/01/17 16:14:56.478 172.18.32.21:23 read 1
>> 3
>> T
>> O
>> R
>> 2011/01/17 16:14:56.479 172.18.32.21:23 read 1
>> R
>> \r
>> Can someone tell me what is going on here?
>> Regards and thanks,
>> John Dobbins
>> Cornell University
>> Lab for Elementary Particle Physics
Eric Norum
[email protected]
- Re: StreamDevice/ASYN connection to a Telnet port Daron Chabot
- StreamDevice/ASYN connection to a Telnet port John Dobbins
- Re: StreamDevice/ASYN connection to a Telnet port Dirk Zimoch
Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
<2011>
2025
<2011>
2025
