1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12
Date: Fri, 11 Feb 2011 11:55:14 -0800
Hi Andrew,
Sent from my iPhone
On Feb 11, 2011, at 11:39, Andrew Johnson <[email protected]> wrote:
> On Friday 11 February 2011 13:17:22 Jeff Hill wrote:
>>> I have the following running under ...
>>> vxWorks 6.8:
>>> Intel Dual Core
>> You must be one of the first sites running EPICS on the new symmetric
>> multiprocessing (SMP) vxWorks!
> Ernest, if you have more than one core enabled I can _guarantee_ that your IOC
> is not going to run properly.  Our vxWorks OSD code is not ready for SMP
I will look into turning off SMP
> operation yet, it needs someone to go through it with a fine tooth-comb, which
> might be a good Codeathon project for one of your guys.
>>> Must I throw the  "-mlong"  flag?
>>> I thought that was only for the PowerPC architecture.?
> It's not going to be as simple as that.
> Please try running the libCom test suite on this CPU first:
>    cd "/path/to/epics/base"
>    ld 0,0, "bin/vxWorks-xxx/vxTestHarness.munch"
>    epicsRunLibComTests
> Any test failures in the results should give a few ideas of places that will
> need a closer look.
Sounds good
I will do that next :)
Cheers
Ernest
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
Prev: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Andrew Johnson
Next: RE: Installing EPICS on Windows machine Morgan Bradford
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Ernest L. Williams Jr.
