1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE : Error vxi11 with Lecroy 760Zi
To: "Mark Rivers" <[email protected]>, <[email protected]>
Date: Tue, 15 Feb 2011 07:32:55 +0100
Title: RE : Error vxi11 with Lecroy 760Zi
I use the last version of ASYN.
This scope integrates also the VICP protocol. But when I use drvAsynIPPortConfigure("TCP_SCOPE","132.166.33.202:1861",0,0,0), nothing happens. I have not sure about the PORT. They use this PORT to communicate with their LECROY soft.
thanks,
Jean-François
-------- Message d'origine--------
De: Mark Rivers [mailto:[email protected]]
Date: lun. 14/02/2011 21:06
À: DENIS Jean-françois; [email protected]
Objet : RE: Error vxi11 with Lecroy 760Zi
What version of asyn are you using?  There were some recent fixes for vxi11.
From: [email protected] on behalf of DENIS Jean-françois
Sent: Mon 2/14/2011 4:14 AM
To: [email protected]
Subject: Error vxi11 with Lecroy 760Zi
Hello,
I want to control a Lecroy scope WavePro 760Zi with EPICS. This scope integrate a vxi11 server.
I don't know how to do it. Many solutions
I think to start the simplest solution is with ASYN and STREAM DEVICE, but I have problem.
My configuration is:
st.cmd => vxi11Configure("TCP_SCOPE","132.166.33.202",1,0.0,"inst0",0,0)
Lecroy.db => record(waveform, "$(NOMOP):IDN")
         field(DTYP, "stream")
         field(INP, "@Lecroy_proto.db test TCP_SCOPE")
         field(NELM, "200")
         field(FTVL, "STRING")
lecroy_proto.db => test{
                        out "*IDN?";
                        in "%s";
Error =>
        iocLecroyLx > 2011/02/14 08:48:04.125 TCP_SCOPE vxi11 clientCall errno Permission denied clnt_stat 5
        2011/02/14 08:48:04.125 TCP_SCOPE vxiCreateIrqChannel (create_intr_chan): RPC: Timed out
        2011/02/14 08:48:04.125 TCP_SCOPE Warning -- SRQ not operational.
        2011/02/14 08:48:08.126 TCP_SCOPE vxi11 clientCall errno Success clnt_stat 5
        TCP_SCOPE vxiSrqEnable RPC error : RPC: Timed out
        2011/02/14 08:48:08.126 TCP_SCOPE asynGpib:pollAddr srqEnable
        2011/02/14 08:48:12.126 TCP_SCOPE vxi11 clientIoCall errno Success clnt_stat 5
        2011/02/14 08:48:12.126 TCP_SCOPE Lecoy:IDN: asynError in write: TCP_SCOPE RPC failed
I don't understand why...
Another solution is to install a EPICS base on the scope (windows 7), and use their library ActiveDSO. Is it a good idea?
Thanks.
Jean-François DENIS
CEA Saclay
Error vxi11 with Lecroy 760Zi DENIS Jean-françois
RE: Error vxi11 with Lecroy 760Zi Mark Rivers
Prev: no envPaths in application of base 3.14.11 Mi Qingru
Next: RE: USB4000 David Beauregard
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Error vxi11 with Lecroy 760Zi Mark Rivers
Next: Re: Error vxi11 with Lecroy 760Zi Peter . Mueller
