1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Config for 2 Ethernet Adapters
To: [email protected]
Cc: [email protected]
Date: Tue, 15 Feb 2011 10:52:37 -0500
Look in the CA Reference Manual for your release of EPICS.  I think
you need to specify EPICS_CAS_INTF_ADDR_LIST .
-ps
On Tue, Feb 15, 2011 at 10:33,  <[email protected]> wrote:
> Hi,
> I have a Linux x86 IOC which takes data from a legacy control system and converts it to EPICS data.  Where both controls systems co-exist on one network the IOC works fine running on a single ethernet adapter machine.
> I now need to take the legacy data from one network and make available on another network via EPICS.  I have a Linux PC with 2 ethernet adapters, eth0 the legacy control system, eth1 the EPICS control system.  The IOC runs on this machine except I cannot see the EPICS PVs via other machines on the eth1 network.
> I'm guessing that the EPICS IOC is binding to eth0 by default and expecting to serve data to this network?
> How do I configure EPICS to bind to eth1 rather than to eth0, is this possible?
> Thanks,
> Graham--
> Scanned by iCritical.
Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
EPICS Config for 2 Ethernet Adapters graham.cox
Prev: Re: no envPaths in application of base 3.14.11 Andrew Johnson
Next: Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Config for 2 Ethernet Adapters graham.cox
