1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: soft ioc runs into fatal exception (base-3.14.12)
To: [email protected]
Date: Wed, 16 Feb 2011 10:58:42 -0600
On Wednesday 16 February 2011 07:39:01 Carsten Winkler wrote:
> After patching of 'src/libCom/osi/os/WIN32/osdThread.c' and
> 'src/ca/tcpiiu.cpp' all seems to work fine now!
> Thank you very much!!!
> Hope this patches will be posted to "Known Problems".
Done, thanks.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
RE: soft ioc runs into fatal exception (base-3.14.12) Jeff Hill
Re: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
Prev: Re: soft ioc runs into fatal exception (base-3.14.12) Carsten Winkler
Next: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: no space in pool for a new client (below max block thresh) in EPICS R3.14.12 Jeff Hill
