1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: stream without asynPort
To: EPICS tech-talk <[email protected]>
Date: Thu, 17 Feb 2011 10:00:32 -0800
Hello,
I am tryign to use a feature I have seen in stream protocols.
I would like to call iocsh function from a process variable.
ex:
when a bo record is set to 1, I would like to execute 'dbl' in the iocsh.
Q: is it possible to use stream without instanciating a asynPort ?
Q: is there another SIMPLE way to do this other than with stream ?
Q: apropos is it possible in stream to pass the value of the PV in exec lines?
   ex: exec "dbpr mbboPV <valueOfMbboPV>" ;
Emmanuel
Re: stream without asynPort Eric Norum
Re: stream without asynPort Rod Nussbaumer
Re: stream without asynPort Dirk Zimoch
Prev: Re: Error vxi11 with Lecroy 760Zi Peter . Mueller
Next: Re: stream without asynPort Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: cygwin and DOS caget, caput running slow at end due to ca_context_destroy(), option to speed up execution? Jeff Hill
