1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Make target_arch only ... doesn't seem to work on 3.14.11
To: EPICS tech-talk <[email protected]>
Date: Fri, 18 Feb 2011 15:12:28 -0800
I have a 64bit machine which is used to compile arm binaries.
make linux-armv4tl
according to the manual should build only for the arm system.
But obviously it doesn't. First the compilation starts with the host architecture
(linux-x86_64 in my case)
Q: Is there a way to compile only for a specific T_A ?
The host native gcc doesn't compile the ARM assembly code correctly.
See below
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500
-D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DDEBUG  -m64
-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
-I/usr/local/epics/base/3.14.11/include/os/Linux -I/usr/local/epics/base/3.14.11/include
-I/usr/local/epics/extras/3_14_11-20110107_142859/asyn/4-12-20110107_152039/include
-I/usr/local/epics/extras/3_14_11-20110107_142859/calc/2-7-20110107_151847/include
-I/usr/local/epics/extras/3_14_11-20110107_142859/genSub/1-6a-20110107_151216/include
-I/usr/local/epics/extras/3_14_11-20110107_142859/sscan/2-6-5-20110107_151705/include
-I/usr/local/epics/extras/3_14_11-20110107_142859/stream/2-4a-20110107_153019/include
../portThread_useHardware.c
../peekpoke.h: Assembler messages:
../peekpoke.h:39: Error: invalid char '[' beginning operand 2 `[ %rax]'
make[1]: *** [portThread_useHardware.o] Error 1
make[1]: Leaving directory
`/home/cls1fs/epics/epics2/svn/iocs/cls1/drv/ts7000/src/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
Emmanuel
Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Prev: RE: GigE cameras stops Pavel Stoffel
Next: Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: GigE cameras stops Bruce Hill
