1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epics on FreeBSD: broadcast problem
To: [email protected]
Date: Wed, 23 Feb 2011 17:25:20 +0100
Hi all,
Recently I tried to run epics under FreeBSD for the first time. I have a
fairly recent FreeBSD 8.1-something and the latest epics 3.14.12.
Compilation went without any problem. However, I cannot get any PVs from
my network with caget on the FreeBSD machine, they all give me "Channel
connect timed out".
For testing purposes I started a softIOC of the FreeBSD machine. PVs from
this softIOC can be seen just fine from other Linux machines in the net
using caget. But on the FreeBSD machine itself I still only get the
timeout.
Then I included the machine's IP explicitely into EPICS_CA_ADDR_LIST. After
this, I could get the PV coming from my local softIOC. But even adding
another IOC's address in the network to EPICS_CA_ADDR_LIST did not let me
resolve any of its PVs with caget from the FreeBSD machine.
This made be suspicious that something with broadcasting might be wrong.
And indeed I could fix the problem by setting EPICS_CA_ADDR_LIST
explicitely to the broadcast address of my subnet (192.168.95.255, which
might be a bit unusual, but has never caused any problems so far with
Linux machines).
Is there anything different with the handling of broadcasts and/or
interfaces when using FreeBSD? Linux just works out-of-the-box and does
not require setting EPICS_CA_ADDR_LIST.
cu
  Gerrit
Re: epics on FreeBSD: broadcast problem emmanuel_mayssat
RE: epics on FreeBSD: broadcast problem Jeff Hill
Prev: RE: asyn interrupts... racing conditions?:w Mark Rivers
Next: Re: epics on FreeBSD: broadcast problem emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
