1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem with VxWorks RTC (seems to be caused by tpmac Delta Tau communications, creates problems with autosave)
Date: Thu, 24 Feb 2011 09:44:00 -0800
Hi EPICS folks,
      I'm seeing a problem with my VxWorks RTC that appears to be caused by communications with a Delta Tau VME controller using the tpmac synApps module.
      I turned off the records sending periodic queries to the Delta Tau board. When I send a DPRAM ASCII communications to the Delta Tau board and get a response, then my RTC seems to gets messed up. My evidence that the RTC is messed is that the VxWorks console function call ‘date’ returns with strange dates and doesn't change over time. The VxWorks console function ‘date’ works until the first time I send and get back the DPRAM communications. Has anybody else seen such a problem before? It seems to break autosave functionality as well.
      I'm particularly interested in hearing if anybody else has seen RTC problems such as these due to Delta Tau communications or any other causes, because that might shed some light on what is causing my problem. I'm using the MV6100 PPC CPU VME board with VxWorks version 5.5.2.
Cheers,
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Prev: Anyone working on PCO camera support? peter.leicester
Next: RE: Anyone working on PCO camera support? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Anyone working on PCO camera support? Brands Helge
Next: About pvPut dafault behavior jun-ichi.odagiri
