1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: About pvPut dafault behavior
To: <[email protected]>
Date: Fri, 25 Feb 2011 10:26:50 +0100
On Friday, February 25, 2011, [email protected] wrote:
> Dear all;
> I'm looking into the following site to check if pvPut of seq-2.0.11
> works synchronously or asynchronously (with NO compiler option and
> NO explicit SYNC/ASYNC option, just a pvPut(pvname) call).
> http://www-csr.bessy.de/control/SoftDist/sequencer/Manual.html
> In "Notes on Release 2.0 (Synchronous/asynchronous override on gets and
> puts)",
> it says as follwos:
> "pvGet and pvPut both accept an optional SYNC or ASYNC argument that,
> for pvGet, overrides the default as set using the -a option and, for
> pvPut, overrides the default synchronous behavior."
> So, I thought pvPut(pvname) works synchronously. However, it say in
> "Asynchronous Use of pvPut" as follows:
> "Normally the pvPut operation completes asynchronously. In the past it
> has been the responsibility of the programmer to ensure that the
> operation completed (typically by monitoring other variables). However,
> the function pvPutComplete can now be used for this."
> So, I'm getting confused.
> Does pvPut(pvname) work synchronously, or asynchronously by default?
> Sorry in advance if I'm bothering you all due to my poor ability in
> reading English.
Not at all. You are pointing out a bug in the release notes: the first
paragraph is wrong as stated; I am going to fix that. The default behaviour
for pvPut is definitely asynchronous, or, to put it more precisely, pvPut
sends the request off to the PV and does *not* wait for any confirmation (in
fact never requests it in the first place). In short: it is a fire and
forget operation.
It may be clarifying to point out that for the pvPut operation, the
synchronous/asynchronous distinction is not enough to completely describe
the behaviour. There are actually three variants, one synchronous and two
asynchronous:
* pvPut(var): fire and forget, no completion message is requested
* pvPut(var,SYNC): request completion message, block state set (thread)
  until it arrives (or timeout occurs)
* pvPut(var,ASYNC): request completion message but do not block state
  set; instead user code can call pvPutComplete to find out if completion
  message has arrived
Note that pvPut is *not* affected by the +a or -a options given to the snc
compiler. These options only change the default behaviour of pvGet.
You can find a more detailed description of the pvPut and pvGet (and all
other) commands in the online SNL reference at
http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html
HTH
Ben
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: About pvPut dafault behavior jun-ichi.odagiri
Prev: Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Next: Re: About pvPut dafault behavior jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: About pvPut dafault behavior jun-ichi.odagiri
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
