1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Problem with Motor Record on RTEMS on MVME5500
To: Kate Feng <[email protected]>, Jim Eastman <[email protected]>
Date: Tue, 1 Mar 2011 11:34:50 -0800
> You can add the following line in your startup script
> bspExtVerbosity=0
I like to reset bspExtVerbosity=1 after iocInit since at that point, I want to know if there's something that "kills real-time performance".
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Kate Feng
> Sent: Tuesday, March 01, 2011 9:29 AM
> To: Jim Eastman
> Cc: EPICS Tech Talk
> Subject: Re: Problem with Motor Record on RTEMS on MVME5500
> Jim Eastman wrote:
> > Hi Kate,
> > Thank you very much for that! That did the trick.
> bspExtVerbosity=0
> For example, before the line of
> dbLoadDatabase("/epics/mvme5500/dbd/motorRecord.dbd")
> This will take out all of the warning lines
>  > libbspExt - Warning: it seems that MCP support is not available on
>  > your CPU
>  >                      or not implemented by your board. Address probing
>  > must
>  >                      be performed in polling mode with interrupts
>  > disabled
> Regards,
> Kate
> > Regards,
> > Jim Eastman
> > From: Kate Feng [mailto:[email protected]]
> > Sent: Tue 01-Mar-11 08:54
> > To: Jim Eastman
> > Cc: EPICS Tech Talk
> > Jim Eastman wrote:
> > > Hi all,
> > > So continuing to learn my way through all of this, I'm encountering a
> > > problem with using the motor record to control a MAXv. The basic
> > > setup: an MVME5500 running RTEMS 4.10 (with the bspExt code for the
> > > mvme5500), and I've tried both 3.14.11 and 3.14.12 versions of EPICS
> > > using version 6-5-2 of the motor record. Building and deploying the
> > > NoAsyn example app.
> > > Here is my startup output:
> > > Welcome to rtems-4.10.0(PowerPC/Generic (classic FPU)/mvme5500) on
> > > MVME5500-0163
> > > Now BSP_mem_size = 0x1FE00000
> > > Marvell GT64260B (Discovery I) hostbridge detected at bus0 slot0
> > > BSP unlisted vendor, Bus0 Slot10 DeviceID 0x263388
> > > TUNDRA PCI-VME bridge detected at bus1 slot0
> > > Marvell GT64260B (Discovery I) hostbridge detected at bus8 slot0
> > > BSP unlisted vendor, Bus8 Slot10 DeviceID 0x10088086
> > > Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
> > > Universe Master Ports:
> > > Port  VME-Addr   Size       PCI-Adrs   Mode:
> > > 0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
> > > 1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
> > > 2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
> > > Universe Slave Ports:
> > > 0:    0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN,
> > > PREN
> > > Overriding main IRQ line PCI info with 76
> > > Registering /dev/console as minor 0 (==/dev/ttyS0)
> > > ***** Initializing network *****
> > > Startup.
> > > Attaching MVME5500 1GHz NIC1
> > > RTEMS-mvme5500 BSP Copyright (c) 2004,2005,2008, Brookhaven National
> > > Lab., Shuchen Kate Feng
> > > ***** Initializing NFS *****
> > > Mount 10.40.30.108:/tftpboot/epics on /epics
> > > RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> > > LICENSE file for licensing info.
> > > RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> > > ***** Starting EPICS application *****
> > > #Startup script for loading and configuring an OMS MAXv controller.
> > > < /epics/mvme5500/envPaths
> > > epicsEnvSet("ARCH","RTEMS-mvme5500")
> > > epicsEnvSet("IOC","iocNoAsyn")
> > > dbLoadDatabase("/epics/mvme5500/dbd/devOms.dbd")
> > > dbLoadDatabase("/epics/mvme5500/dbd/NoAsyn.dbd")
> > > NoAsyn_registerRecordDeviceDriver(pdbbase)
> > > dbLoadTemplate("/epics/mvme5500/motor.substitutions")
> > > MAXvSetup(1, 16, 0xF000, 190, 5, 10)
> > > MAXvConfig(0, "AX LL PSO; AY LL PSO; AZ LL PSO; AT LL PSO; AU LH PSO;
> > > AV LH PSO; AR LH PSO; AS LH PSO;")
> > > iocInit
> > > Starting iocInit
> > > ## EPICS R3.14.12 $Date: Wed 2010-11-24 14:50:38 -0600$
> > > ## EPICS Base built Feb 25 2011
> > > your CPU
> > > must
> > > disabled
> > > Warning: bspExtMemProbe kills real-time performance.
> > >          Your BSP does or can not use MCP exceptions - we
> > >          must probe with INTERRUPTS DISABLED !!!
> > >          use only during driver initialization
> > >          clear the 'bspExtVerbosity' variable to silence this warning
> > > Illegal field value PV: IOC:m1 motor_init_record_com(): card does not
> > > exist!
> > The jumper on the board is manufactured set to be "user mode".  One
> > needs to set it
> > to a "Supervisory mode" to get it working.  Hope this helps.  I would
> > have to find the
> > user's manual to find out which jumper it is.
> > Cheers,
> > Kate
> > > Illegal field value PV: IOC:m2 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m3 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m4 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m5 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m6 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m7 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m8 motor_init_record_com(): card does not
> > > exist!
> > > iocRun: All initialization complete
> > > Here's what my motor.substitutions file looks like:
> > > file "/epics/mvme5500/db/basic_motor.db"
> > > pattern
> > > {P,     N,  M,        DTYP,        C,  S,  DESC,
> > > EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,
> > > PREC,  DHLM,  DLLM,  INIT,     PREM,  POST}
> > > {IOC:,  1,  "m$(N)",  "OMS MAXv",  0,  0,  "motor axis $(N)",
> > > degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,
> > > 5,     100,   -100,  "AN LL",  "AF",  "AN"}
> > > {IOC:,  2,  "m$(N)",  "OMS MAXv",  0,  1,  "motor axis $(N)",
> > > {IOC:,  3,  "m$(N)",  "OMS MAXv",  0,  2,  "motor axis $(N)",
> > > {IOC:,  4,  "m$(N)",  "OMS MAXv",  0,  3,  "motor axis $(N)",
> > > {IOC:,  5,  "m$(N)",  "OMS MAXv",  0,  4,  "motor axis $(N)",
> > > {IOC:,  6,  "m$(N)",  "OMS MAXv",  0,  5,  "motor axis $(N)",
> > > {IOC:,  7,  "m$(N)",  "OMS MAXv",  0,  6,  "motor axis $(N)",
> > > {IOC:,  8,  "m$(N)",  "OMS MAXv",  0,  7,  "motor axis $(N)",
> > > I'm not sure why I'm not able to communicate with the MAXv controller
> > > ( maybe it has something to do with the bspExt warnings? ). I hope
> > > that covers the relevant details. Any help or advice would be greatly
> > > appreciated. Thanks!
> > > Regards,
> > > Jim Eastman
> > > This e-mail and any attachment(s) are from Pro-Dex, Inc. and may
> > > contain information that is confidential or privileged. If you are not
> > > the intended recipient, do not read, copy or distribute the e-mail or
> > > any attachments. Instead, please notify the sender at the phone number
> > > indicated above and delete the e-mail and any attachments. Thank you.
Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
RE: Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
Prev: RE: edl2boy? Chen, Xihui
Next: How to know if a PV is on a Soft IOC or not ? haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
