1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: subscribing to too many channels on a gateway?
To: [email protected]
Date: Sat, 05 Mar 2011 15:50:03 +0100
On 04.03.2011 23:04 [email protected] wrote:
I was wondering if anyone has been able to connect and subscribe to
something on the order of 60,000 channels through an Epics gateway?
The biggest instance at BESSY II (its clients being archive engines) has ~45,000 active connections.
I've been getting
CA.Client.Exception...............................................
     Warning: "Virtual circuit disconnect"
     Context: "10.20.0.5:5064"
     Source File: ../cac.cpp line 1145
     Current Time: Fri Mar 04 2011 13:17:31.918937653
and then I lose connection to all the channels and need to restart the
gateway. I can't find any errors that would seem to point to anything in
the gateway log.
Is that snipped from the Gateway log? That would mean one IOC (with the given IP/port) shuts down the connection to the gateway. If you lose all channels at that moment - does that single IOC really run all 60,000 channels? If not, whose IP is that?
Does that happen when the Gateway starts up? When clients connect? Even later?
Can the same client(s) connect to the 60,000 channels directly w/o problems?
Looks unusual, at least.
~Ralph
subscribing to too many channels on a gateway? pthomas
Prev: subscribing to too many channels on a gateway? pthomas
Next: Setting inter-character delay in Asyn Prachi Chitnis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
