Hi John,
On Tuesday 08 March 2011 10:45:55 John Dobbins wrote:
> A vendor of hardware would like to test the robustness of their network
> stack in an EPICS environment. Does anyone know of an easy way to
> generate fake EPICS channel search broadcasts for this purpose? (So they
> can test their hardware without an actual EPICS system).
It would probably be easiest to write a simple CA client that does searches of
a set of random channel names, and maybe send the vendor a statically-compiled
binary of that program. Note that the search rate decays over time so you may
want to cancel the oldest searches and re-submit them if you want a sustained
packet rate.
I wrote a simple CAS tool that can monitor and report the current search rate,
or you can try the caSnooper extension program, which is a bit more complex.
> Alternatively, where would I find a description of the contents of the
> channel search request packet?
The CA protocol was documented by CosyLab and is available at
http://epics.cosylab.com/cosyjava/JCA-Common/Documentation/CAproto.html
You might also find the Channel Access Dissector for Wireshark useful, see
http://www-linac.kek.jp/cont/epics/wireshark/
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- generating fake broadcasts John Dobbins
Re: generating fake broadcasts Guy Jennings
PyEpics segmentation faults Vigder, Mark
<2011>
2025
<2011>
2025
