1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: how to build c++
To: yangyong203 <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 30 Mar 2011 09:36:56 +0200
Andrew Johnson wrote:
On Tuesday 29 March 2011 07:11:57 yangyong203 wrote:
My error messages as follow:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I.
-I.. -I../../../include/os/Linux -I../../../include
-I/epics0320/base/include/os/Linux -I/epics0320/base/include ../dbSubExample.cpp
In file included from ../dbSubExample.cpp:6:
/epics0320/base/include/aSubRecord.h:163: error: expected unqualified-id
before ‘!’ token
Ah, this is a very specific problem with the aSub record, which contains a field named 'NOT', which becomes a structure data member 'not'. The word 'not' is a reserved word in C++ (which the compiler has replaced with the synonym '!' in the above error message) but not in C, thus the dbSubExample.c file compiles but it doesn't if you rename it and try to use the C++ compiler.
There is a very simple fix though: Insert the following macro definition into your dbSubExample.cpp file before the #include <aSubRecord.h> line:
	#define not no_t
This will change the name that the C++ compiler sees for that data member into something that it accepts, and the result should then compile properly.
- Andrew
... or add CXXFLAGS+=-fno-operator-names to one of the used CONFIG.* files.
Dirk
Re: how to build c++ Andrew Johnson
Prev: Re: how to build c++ Andrew Johnson
Next: RE: Intelligent Temperature and MKS Instruments TechTalk question emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: CA and threads Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
