1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EDM start window position
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 04 Apr 2011 09:19:33 -0600
Yes, there is a way to specify the location of an EDM window from the commandline. For example -open screen.edl?300?400 will open screen.edl at X=300, Y=400 (You can also specify a display if your monitors are configured as separate displays). See:
http://ics-web.sns.ornl.gov/edm/edmUserManual/index.html#id3488573
However, I modified our copy of EDM to handle multiple displays in the same way as our previous display manager. Since our 6 monitor displays are configured as a single display, we run a separate copy of edm (with a different port) for each monitor. An environmental variable (set to the upper left hand corner for each screen) gets added to the window positions. Essentially, this make window positions relative to the upper left hand corner of the monitor. I can make the code available if anyone is interested.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
Prev: RE: MAXv question matthew.pearson
Next: Re: sequencer on 64bit linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: EDM start window position emmanuel_mayssat
Next: EPICS Collaboration Meeting Fall 2011, First Announcement Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
