1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: how to use EPICS driver of MicroResearch PMC-EVR
To: 王林 <[email protected]>
Cc: [email protected]
Date: Tue, 05 Apr 2011 16:01:18 -0400
Hello,
I believe that the mrfEventSystem driver supports the PMC-EVR-200 model.  The PMC-EVR-230 is supported by the mrfioc2 driver also on sourceforge.  If you have the 230 firmware then the following may be of interest.
We (Eric, Jayesh, and myself) have not yet made a release, but the code is stabilizing and we plan to do so soon.  There is some documentation in the form of a Lyx document in the source repository 'documentation/evr-usage.lyx'.  The latest pre-release version is:
https://pubweb.bnl.gov/~mdavidsaver/files/evr-usage-r4.pdf
I hope this is helpful,
Michael
On 4/5/2011 11:16 AM, 王林 wrote:
I want to use my PMC-EVR, the EPICS driver is from
the underlying files related to the PMC-EVR mainly are mrfPmc.c and os/vxWorks/mrfPmcOSD.c, but I don't know which dbd file, record support and device support I should use. The er and erevent record, as well as the device/driver support devMrfEr.c/drvMrfEr.c may not fit, since some registers of PMC-EVR are different from EVR-200/EVR-230's, such as FPS(front panel signal) map.
So what should I do for building EPICS application for PMC-EVR? How did you build it for your PMC-EVR?
Lin Wang
how to use EPICS driver of MicroResearch PMC-EVR 王林
Prev: Re: sequencer on 64bit linux Andrew Johnson
Next: Re: More base 3.14.12 problems on solaris-spac (version 5.8) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: how to use EPICS driver of MicroResearch PMC-EVR 王林
Next: Ether/IP array limits Stephen Lewis
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
