Thank you Andrew,
This actually is an important fix for me, as we presently can't use the epicsQt GUIs for controlling XPS motors. For the mean time, I have put together some EDM screens which allow us to continue work.
Zen
> -----Original Message-----
> From: Andrew Rhyder [mailto:[email protected]]
> Sent: Sunday, April 17, 2011 10:01 PM
> To: Szalata, Zenon M.; Andrew Johnson; [email protected]
> Subject: RE: epicsQt
> It's definitely a bug in epicsqt. When a connection is restored the code should
> have initialized some internals to ensure any half baked operation in progress
> when the connection was lost is cleared down. Instead it actually initiated a
> write. It's a simple fix and I hope to have it up on source forge with some other
> changes relating to how epicsqt handles arrays in the next few days.
> There is only one button that is epics aware, but it can write values on pressed,
> released, clicked, or a combination of these. So a momentary action which may
> be suitable can be achieved by giving it a pressed and released value to write.
> (Other buttons available launch an application, and open another epicsqt gui.)
> Regards
> Andrew
> From: Szalata, Zenon M. [[email protected]]
> Sent: Saturday, 16 April 2011 6:38 AM
> To: Andrew Johnson; [email protected]
> Cc: Andrew Rhyder
> Hi Andrew,
> Thank you for your input.
> With TPRO set to 1, I get:
> epics> CAS-client: Process TEST:AO:TEST
> CAS-client: Process TEST:AI:TEST
> when the button is clicked, and
> when the IOC is restarted.
> Only one button is available, which is EPICS "aware". It can write different
> values on press, relase
> Thanks again,
> Zen
> > From: Andrew Johnson [mailto:[email protected]]
> > Sent: Friday, April 15, 2011 1:27 PM
> > To: [email protected]
> > Cc: Szalata, Zenon M.; Andrew Rhyder
> > Subject: Re: epicsQt
> > Hi Zen,
> > On Friday 15 April 2011 15:03:43 Szalata, Zenon M. wrote:
> > > I start camonitor TEST:AI:TEST, then the IOC, then the GUI. All seem well.
> > > camonitor reports value 0.
> > > I restart the IOC, camonitor reports PV disconnected, then it connects and
> > > shows value 0. So far so good.
> > > Now I click the push button, camonitor reports value 1.75 as it should.
> > > shows value 1.75!
> > > From now on, after restarting the IOC, the ai record ends up with
> > > value=1.75, even though I am not clicking the push button. Appears that
> > > the ao record is getting processed when the push button connects to the
> > > PV when the IOC starts up. This continues as long as the QT GUI is up.
> > > When I stop the QT GUI and restart the IOC, then restarting the IOC does
> > > not get the value transferred from the ao to the ai record.
> > This sounds like it has to be an epicsQt issue. Try setting the TPRO field of
> > your TEST:AO:TEST record in the .db file; that results in a message being
> > printed on the IOC console whenever the record processes, and it tells you
> > which thread is causing the processing on restarting the IOC. I'm going to
> > bet that you'll see it coming from the same CA thread as when you first push
> > the button.
> > > Am I doing something wrong configuring the epicsQt push button or is
> there
> > > a bug in the epicsQt CA part of the software? I am assuming that this
> > > behavior is not built in intentionally.
> > Does epicsQt have more than one kind of push button? I would like for
> > something like a momentary action button if there is an alternative you can
> > use. It sounds like the one you're using is designed to restore the last
> > value it sent when the IOC reconnects, which isn't what you actually want it
> > to do.
> > HTH,
> > - Andrew
> > An error is only a mistake if you don't learn from it.
> > When you learn something from it, it becomes a lesson.
> <br>This message and any attachments may contain proprietary or confidential
> information. If you are not the intended recipient or you received the message
> in error, you must not use, copy or distribute the message. Please notify the
> sender immediately and destroy the original message. Thank you.
- epicsQt Szalata, Zenon M.
- Re: epicsQt Andrew Johnson
- RE: epicsQt Szalata, Zenon M.
- RE: epicsQt Andrew Rhyder
Re: How to know type of record at client end [Py-epics v3.1.1 interface ] Dirk Zimoch
Re: ioc segfault if - c seq flag is not set or +c? Benjamin Franksen
<2011>
2025
pdevLibVirtualOS Terry Cornall
<2011>
2025
