Subject: |
Large number of sequencers running per soft IOC under Linux: Kernel becomes unresponsive |
"Ernest L. Williams Jr." <[email protected]> |
To: |
Tech-talk <[email protected]> |
Date: |
Wed, 27 Apr 2011 08:18:27 -0700 |
When reviewing the recent "gateway aborted by SIGBUS" EPICS tech-talk
thread; I recall a possibly related issue.
Here I am referring to understanding what system resources are impacted
as the number of softIOC(s) grows
per "linux server"
We had an incident in which there were 11 linux-based softIOCs each
running 1190 EPICS sequencers.
When only 10 of the softIOCs were running the linux system was responsive.
However, when the 11th IOC was launched we came to a "screeching halt". :(
We could not remotely log in; even at the console we could do nothing.
The only way to recover was to reboot the linux server.
Our computer systems group noticed that the default number of "file
descriptors" per process system wide was 1024.
Our team also monitored many of the linux system resources during the
instantiation of the 11 softIOCs.
When 10 softIOCs are running each with 1192 EPICS sequencers the linux
system wide resources seemed to be no where near
the limit. That is we monitored CPU load , Memory, I/O Activity, etc...
When the number of file descriptors per process was increased to 2048
the problem remained.
An increase in the number of file descriptors per process to 4096 also
failed.
In the end, the computer systems group increased the default number of
file descriptors per process to "8192" and the problem was solved.
We still do not understand the relationship between the linux system
resources and how are softIOCs w/sequencers drive us into some
linux system limitation.
When looking at the number of file descriptors for a single softIOC, it
is well below the default limit.
Using iocAdmin EPICS Module we look at: <>:FD_MAX and <>:FD_FREE
SIOC:LI25:KY00:FD_MAX = 8192
SIOC:LI25:KY00:FD_FREE = 8173
Appears that only 19 FD(s) are being used. So, I am at a lost.
Has anyone else seen an issue like this?
Any ideas and references will be appreciated.
Handle leak in Channel Access Server V4.13 (current EPICS base) - WinXP Carsten Winkler
areaDetector Prosilica IOCs on Windows 7? Mark Rivers
<2011>
2025
RE: Handle leak in Channel Access Server V4.13 (current EPICS base) - WinXP Jeff Hill
<2011>
2025
