Subject: |
RE: Suggestion for IOC log server |
"Davidsaver, Michael" <[email protected]> |
To: |
"EPICS Tech Talk" <[email protected]> |
Date: |
Tue, 24 May 2011 13:58:10 -0400 |
Another nice feature of conserver is that the local daemon can redirect clients to daemons running on other machines. So you can attach to procServ instances running on other hosts directly without needing (or allowing) ssh access.
For our test lab we have some RTEMS iocs and soft iocs on several hosts. The method for connection and logging is uniform.
$ console -u
mad up jshah@localhost
timing up mdavidsaver@localhost
sumtest up <none>
wiener up <none>
OM_Lab up <none>
RadMonAvg up <none>
RadMon up <none>
vioc down <none>
fritz up <none>
v7768 up <none>
alpha up <none>
rftiming up <none>
acqiris up <none>
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Ralph Lange
> Sent: Tuesday, May 24, 2011 10:54 AM
> To: EPICS Tech Talk
> Subject: Re: Suggestion for IOC log server
> On 24.05.2011 16:33 Williams Jr., Ernest L. wrote:
> > Hi
> > Is this the same as procServ
> One layer above.
> procServ allows telnet access to soft IOCs - it is the "soft" one
> channel version of a console server (aka Moxa box or equivalent).
> Conserver [1] is a daemon that connects to console connections -
> provided by procServ, Moxa boxes, serial lines, etc.
> The conserver daemon basically keeps the connection to all the consoles
> up and does the logging. It also provides a TCP based service that
> allows
> users to connect to consoles by means of a client program called
> console. The conserver daemon provides authentication for these user
> connections,
> makes sure only one gets write access, etc.
> The user calls "console <iocname>", which connects to the conserver
> daemon.
> The conserver daemon authenticates the user, and connects the user to
> the console connection of the specified IOC.
> That IOC can be a soft IOC under procServ, a VME IOC connected to a
> terminal server, anything serial connected somehow to something. The
> connection
> details are part of the conserver daemon configuration, the user only
> needs the IOC name.
> Ralph
> [1] http://www.conserver.com/
- Re: Suggestion for IOC log server J. Lewis Muir
- Device Support for Nemic Lambda Power Supplies Anthony Andrews
- Re: Device Support for Nemic Lambda Power Supplies Eric Norum
- Suggestion for IOC log server Abadie Lana
- Re: Suggestion for IOC log server Ralph Lange
- Re: Suggestion for IOC log server Williams Jr., Ernest L.
Another gateway question Kevin Tsubota
<2011>
2025
<2011>
2025
